chrysler hemi extended bell removal
Discussion in 'The Hokey Ass Message Board' started by 17dodgebros, May 21, 2008.
  1. 17dodgebros
    17dodgebros
    has anyone had the extended bell removed on an early chrysler block? if so how much? does it come in kit form?
  2. 41hemi
    41hemi
    I read an article in a hot rod magazine years ago where a machine shop cut off the extended bell then welded the "normal" 55-58 hemi trans pattern to the modified block. You really do not need to cut it off to adapt a later trans to the extended bell engines. Wilcap actually offers an adapter kit to put a 727 or a 904 AUTOMATIC trans behind the long bells without modifying the engine! Basicly you cut the bell off the ****** and bolt their adapter to the front pump along with using other parts from the kit. If you are using a standard trans, then their are many people that offer kits. Wilcap and Hot Hemi Heads offer the standard trans adapters. www.hothemiheads.com www.wilcap.com Good Luck! Al
