Chrysler Hemi oil filter advice
Discussion in 'The Hokey Ass Message Board' started by 1932tub, Feb 12, 2011.
  1. 1932tub
    1932tub
    I am installing a remote filter to a 354 Hemi, the adaptor plate is tapped for 3/8 bsp. Would 3/8 tube be a big enough bore to carry the oil to and from the filter?
    Its not a race engine will only be street driven.
    There is no room to mount a filter to the block even with an adapter.
  2. George
    George
    If it wasn't, the maker would probably been sued out of business by now....:)
  3. 1932tub
    1932tub
    Thanks for your reply George, forgot to mention that the adapter was hand made, nothing factory.
  4. Mopar'd
    Mopar'd
    On my desoto (330) I run a 3/8" I'd hydraulic line. On my 354 I am running a 1/2" line. My thoughts were that I was a little worried about all of the mods that I made in the motor. Could you explain your build of the engine?
  5. Pir8Darryl
    Pir8Darryl
    What's the size of the pickup tube on the oil pump?
    I'm betting it's 1/2", and I'd advise using at least that size... Unless the early hemi is an internal byp*** engine.
    Let me put it to you this way... Check out this thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=297383
    A small block chevy oil pump that's converted to a hand held utility pump. Spinning at 1000 RPM, it moves 4-5 gallons per minute.
    Now the oil pump is cam driven, so it only spins at 1/2 engine RPM, but all the same, at 2000 rpm, it's moving 4 gallons per minute. At 4000 rpm, it'sa moving 8 gallons per minute. Think about what it would take to push 8 gallons per minute thru a 3/8 line... :eek:
    All in all, I think a 3/8 line is just asking for trouble.
  6. 73RR
    73RR
    '-8' minimum.
    ...and the longer the lines the bigger the 'hole'...cold oil (and bearings) will not like the 3/8.
  7. Mopar'd
    Mopar'd
    I thought I would do some calculations on th pressure losses an velocity of oil through the different tubing sizes. (cammeron hydraulic data book)
    all calculations use 4 tpm as the base flow and 30 w oil @ 100 F
    For 3/8" tubing:
    Velocity of the 10.1 ft/s. Loss of psi in 100ft= 50.6 psi
    For 1/2" tubing :
    Velocity = 5.87 ft/s. Loss of psi per 100 ft = 13.8 psi
    For 5/8" tubing :
    velocity= 3.84 ft/s. Loss of psi per 100 ft = 1.66 psi
    with this data you can calculate your losses and determine if it might be a problem. My hoses are a total of 7'. So multiply the pressure loss by .07. In 3/8" tubing a loss of 3.5 psi ; 1/2" would yield .96 psi and with 5/8" = .112 psi.
    I know to much info, but it should show you that the numbers are very small .
  8. 1932tub
    1932tub
    Thanks for the info guys 1/2" tube it is
  9. Pir8Darryl
    Pir8Darryl
    Samrt move :D
    Mopar'd,
    What's the value for "t"? Did you mean "g"?
