Chrysler marine engine mysterium?
Discussion in 'The Hokey Ass Message Board' started by Mr 42, Sep 17, 2005.
  1. Mr 42
    Mr 42
    from Sweden
    Im helping a friend assembling/fix up a Fifties Chrysler Hemi marine engine.
    And when i was looking at the block i saw the word "Sample" cast into the side.
    can anyone tell me what it means??
    And if it was used for anything specific.
  2. squirrel
    I think it means that it belongs in a museum.
  3. Ratfink1915
    Ratfink1915
    from Ohio
    Hmmmm......mabie it means......fuck the museum put it in your car.
  4. Mr 42
    Mr 42
    from Sweden
    No museum
    It will end up in a 13meter mahogany boat from 1936, and 3" copperpipes as exhaust system...
    come on isn't it there any Chrysler specialist's out there...
  5. Mutt
    Mutt
    sam·ple [​IMG] (s[​IMG]m[​IMG]p[​IMG]l)
    n. 1. a. A portion, piece, or segment that is representative of a whole.
    b. An entity that is representative of a class; a specimen. See Synonyms at example.
    I believe "b" covers it nicely. The question is: was it used as a sample because of a defect, or just cast ahead of the factory run? It could be a very rare piece, since MoPar freaks are the most rabid of the "one of" group. On the other hand, it could be just a curiousity. Didn't help much, did I?:D
    Mutt
  6. polisher
    polisher
    Alliance Vendor
    Don't think I'd want copper for an exhaust on a boat.
    Won't it become sacrificial with electrolylsis.
    Copper travels in salt water real easy.
  7. 4tford
    4tford
    Go to www.thehemi.com web site the forum there has a section for marine hemi questions. It most likely is a prototype run for a new casting or something like that. Chrysler usually didn't let those out for use and usually scraped them after they were done with them. But there always seems to be some proto's that show up out there.
  8. squirrel
    that boat sounds to me like a suitable museum in which to display such a rare engine.
  9. Brad54
    Brad54
    from Atl Ga
    Call the Walter P. Chrysler Museum and see if they have any info.
    Also, contact Bob Walker at Hot Heads--he's about seen it all.
    On a serious note, if that is some pre-production "sample", I would SERIOUSLY think about selling it to a collector or a the Walter P museum. If you get enough to simply replace the block with another, you're out nothing but time. If you get a little extra for it, you're ahead, and a rare piece is where others can ogle it. Chrysler enthusiasts would LOVE to see that walking through the museum.
    -Brad
  10. chitbox dodge
    chitbox dodge
    from dunlap tn
    i wouldnt know why your block says sample, but there are some odd things about chrysler marine equipment. for instance they had reverse turning engines for use alongside a second hemi with standard rotation to get out of using v-drives (i suppose). i like the hell out of your friends project though. maybe talk him into using two flat sixes instead. or a mopar straight eight would be cool too.
  11. 51 MERC-CT
    51 MERC-CT
    Probably the name of the guy who made the casting. :confused: :confused: :confused:
  12. jerry
    jerry
    That boat gives me wood!
    Seems to be a suitable receptacle for that motor. Please keep us posted as to progress.
    jerry
  13. muffman58
    muffman58
    Would make a great anchor! '' NO POWER "
  14. I gave a sample once...
  15. George
    George
    Maybe the Garlits museum he has a hemi cut-away engine on display.
