Chrysler poly tri power info needed
Discussion in 'The Hokey Ass Message Board' started by 33mopower, Apr 12, 2009.
  1. 33mopower
    33mopower
    I know the hemi heads bolt right on the chrysler poly motors. The question is do the hemi intakes work on the poly heads?
  2. George
    George
    Doesn't look like it. You seem to have a late Poly with a one piece intake & valley cover. Hemi intakes only work on hemi based Polys with seperate intake & valley cover.
  3. 33mopower
    33mopower
    So the motor pictured is a later poly but the hemi intakes will fit the 301-331-354 poly's. Thanks for the info.
  4. The hemi heads will fit the poly 270, 315, 325 as well...not sure if Dodge, Chrysler and Desoto offered a poly version of all the hemi motors??
    But if you are going Hemi Heads then you need the HEMI intake...so I don't think the poly and HEMI intakes are interchangeable.
  5. George
    George
    All the nuances are explained in the Hemi tech index.
