Chrysler Power Brakes
Discussion in 'The Hokey Ass Message Board' started by Devils-Driver, Mar 11, 2014.
  1. Devils-Driver
    Devils-Driver
    Hi
    i have some questions about the
    Chrysler Brake System.
    Whats is the difference between
    Normal Brake and Power Brake??
    An other Masterzylinder?
    Vacum Booster only with Power Brake
    or with the Normal Brake too?
    I hope it comes a answer.
    Thanks
    Mario
  2. 41hemi
    41hemi
    A Chrysler with power brakes will have a vacuum booster behind the master cylinder. A standard(normal) brake car only has the master cylinder. Hope this helps!
  3. What year Chrysler are you wondering about? I know in my 50 Desoto the master cylinder is on the frame and there would be a raised area under the drivers seat with the booster. You might ask the question on p15-d24.com as they are the experts.
  4. Devils-Driver
    Devils-Driver
    Thanks guys for the first Informations.
    My Chrysler is a 1954 New Yorker.
    And with Power Brakes.
    Andy Bernbaum / Old Mopar Parts
    says that the Normal Brakes and Power Brakes have the same Masterzylinder.
  5. Carbroke
    Carbroke
    Chrysler used to put the vacuum assist unit linked to the pedal linkage so it aided in depressing the master cylinder in parallel to the pressure your foot generated.
    It wasn't like a GM type unit where the master cylinder was mounted right onto the assist chamber.
    So the same master cylinder was used in either situation. However, the actual linkage inside the car is different for a standard unassisted brake system than that used in a power assisted braking system.
    So if you are considering changing from a standard braking system to a vacuum assisted system, you are likely going to want to find the pedal linkage setup for the vacuum assisted type as well.
