chrysler wiring snafu
Discussion in 'The Hokey Ass Message Board' started by stuart13, Jun 21, 2012.
  1. stuart13
    stuart13
    I am running factory wiring in my 54 Chrysler Newyorker and switched from the stock tail lights that had seperate wires for stop,turn and tail light to a LED cateye tail light from Speedway that combines the stop and turn wires. The turn/stop and tail light functions work fine until I step on the brake, it freezes (light stays on but doesnt blink) the front stock turn signal. After I release the brake everything goes back to normal. Any ideas on how to cure the problem with the front turn signal?
  2. squirrel
    Yeah, replace the rear brake/turn lights with separate lights.
    It's backfeeding the brake lights thru the turn signal switch wiring. You only have 3 wires on the turn signal switch, don't you? You need at least 6 wires to use combined turn/stop bulbs in back.
  3. squirrel
  4. stuart13
    stuart13
    I have six wires at the switch.
  5. squirrel
    I guess you're going to have to figure out how the switch works, and how the car is wired. Or else just get one of the trailer adapter things, and see if that fixes it.
  6. d2_willys
    d2_willys
    from Kansas
    I have a 54 NY deluxe. The flasher is a 3 wire unit, so one goes to the ignition switch power, (x), the (L) goes to the front and rear lamps through one pole of the turn signal switch, and the middle (P) is sent to the other pole of the turn signal switch which powers the turn indicators. 6 wires total.
    Re-wire the rear lamps as follows using a trailer converter box:
    Red or stop wire from converter box goes to the stop light switch
    Green goes to the front right turn signal
    Yellow goes to the front left turn signal
    Brown - not needed, for tailights only
    White wire goes to ch***is ground.
    Note: The converter squirrel mentioned will work for negative ground systems 6 or 12 Volt), sorry but 54 Chrysler is positive ground. So you may have to switch to neg ground for it to work. BTW: I work for Hopkins and on the trailer light converter boxes.
    Another approach is to use a couple of relays and some diodes, which will have one for the right rear, the other for left rear.
    I will try and provide a diagram for you.
  7. squirrel
    Thanks for the explanation.
  8. stuart13
    stuart13
    Thank you for this info d2_willys, I love the H.A.M.B.!
