clean aluminum from crankshaft?
Discussion in 'Off Topic Hot Rods & Customs' started by joel fisher, Nov 21, 2024.
  1. joel fisher
    joel fisher
    Has anyone used oven cleaner (similar to lye) to remove aluminum stuck on a crankshaft journal? Honda 8 hp engine gx240 that was run without oil and broke the connecting rod. I want to save the engine as it is a hard to find gear reduction unit. Any suggestions are appreciated
  2. Budget36
    Budget36
    I had the same thing on the same engine. The PO byp***ed the light/no start thing. Spun the rod
    I took the crank to a machine shop, had it polished.
    Didn’t check nor was worried about clearances though, but used the engine for a home built quad for the kids.
    tractorguy likes this.
  3. Unkl Ian
    Unkl Ian
    Muriatic Acid, will eat the Aluminum, and not touch the steel crankshaft.
    Also works when you stick a piston.
  4. KenC
    KenC
    Yep, lye will work. Acids will too if rinsed quickly but overexposure can etch the steel
  5. WashBear2
    WashBear2
    Oven cleaner is the go to for removing aluminum from cylinder walls after smearing a piston in a 2t. Never used it on a crank but I don’t see why it wouldn’t work.
  6. 19Eddy30
    19Eddy30
    from VA
    When Younger , Polished crank with shoe string & emery cloth.
  7. vintage6t
    vintage6t
    from CT
    And it works pretty well.
    ken1949car, tractorguy and Deuces like this.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Heat......Aluminum melts way before steel. Just play the torch slowly over the surface , not lingering or pointing it directly at the journal and then a wire brush to knock it away.
    tractorguy and 19Eddy30 like this.
  9. Deuces
    Deuces
    Yep! I've done it with 400 and 600 grit 3m paper.... Keep a micrometer handy!!!!!....;)
    ken1949car likes this.
