1952-59 Ford Clean Headliner
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Tomato Head, Aug 12, 2010.
  1. Mr. Tomato Head
    Mr. Tomato Head
    Anyone have a suggestion for a product to clean the headliner of my 55 Ford Country Sedan wagon?
  2. Retro Jim
    Retro Jim
    Can you tell us what the headliner is made of ? If original I think a good cleaner you use in the house that doesn't have Bleach in it will work OK . Something like 409 , Mr. Clean , Simple Green and things along that line . I would test in a place like under the visor just in case something goes wrong and really fades the color . At least no one would see it unless the visor is down . Try with a clean rag or old white T shirt . Use white because if the rag has color , it could fade and get the color onto the headliner . You can also use a cleaning brush and a tooth brush in those tight areas .
    Let us know how you make out .
    Jim
  3. Mr. Tomato Head
    Mr. Tomato Head
    I believe it is the original material. Thanks for the advice. Hope to dive in tomorrow. Thanks
  4. Tobey56
    Tobey56
    I had a 65 falcon a few years back. It had the original vinyl head liner in white, and was yellowed from former owner smoking. I used wesley's bleach white on it and it looked like new. Be careful that **** will kill ya if you breath it in. I sprayed it on a white terry cloth rag first then wiped it down with warm water to rinse it.
    Good Luck
  5. jonnys63
    jonnys63
    from So Cal
    Magic eraser.
