Cleaning Alluminum?
Discussion in 'The Hokey Ass Message Board' started by bobbleed, Jun 2, 2005.
  1. bobbleed
    bobbleed
    from Awesome
    Ok, Say You just scored a Sweet Chevelle, with a Sweet motor, and you want to clean it up a bit.....
    It has an alluminum intake and carb, but they are dirty and corroded from dampness....
    What's the best way to clean it? I don't want to take it apart, I just want to clean it in the car.
    Is there some magic solution I can spray?
    I don't need it to be perfect, just freshened up a bit.
    Thanks, Bob
  2. joeycarpunk
    joeycarpunk
    from MN,USA
    A combination of first electrical contact cleaner, than carb cleaner and high pressure water hose has worked for me. Might have to use a brush on stubborn areas.
  3. LUKESTER
    LUKESTER
    "GUNK" carb cleaner for the aluminum intake and a coin operated car wash, maybe a little foamy engine brite, and it will be looking good........ if its really bad.... Dupli-color Cast coat aluminum paint sprayed from 12-16" away ......LUKE
  4. pigpen
    pigpen
    from TX USA
    The Dollar Car Wash that I just used the other day had a selection for "engine cleaner". It came out green! It worked quite well on the aluminum manifold I was working on. :)
    pigpen
  5. polisher
    polisher
    Alliance Vendor
    Pink Stuff, Green Stuff, Regular soap if it's strong, Gunk.
    The secret is to warm the engine first, then the grease just runs.
  6. bobbleed
    bobbleed
    from Awesome
    Thanks, its not so greasy it's more corrosion....
    The car has been stored outside for a few winters....
    The stuff is crusty from standing, not use.
  7. Circus Bear
    Circus Bear
  8. Believe it or not WD-40 works pretty good for dispersing corrosion on aluminum.I used it in the Navy to keep corrosion from forming on bomb rack mechanisms and drop tanks.Salt water spray really does a number on them.
  9. Tim
    Tim
    from KCMO
    hmmm id say gibbs, seems to work on everything else. i think roadsters . com has got it
  10. Deuce Rails
    Deuce Rails
    I don't think that there was a real conclusion to that thread.
    If anyone has a good answer for cleaning up a corroded aluminum intake while it's still in place, I'd like to hear about it.
    --Matt
  11. Roothawg
    Roothawg
    Use the etching mag wheel cleaner......
  12. flatheadpete
    flatheadpete
    from Burton, MI
    Brake parts cleaner works real well.
  13. pigpen
    pigpen
    from TX USA
    You must have been an AO. They told us in the AE shop that WD40 was corrosive and not to use it. We couldn't get it through the supply system. I don't think that it's really corrosive. They probably didn't want to pay for yet another popular ***shaw item. :D
    pigpen
  14. I've also been warned about wd-40 being corrosive. Definatly avoid anything with ammonia.
  15. pigpen
    pigpen
    from TX USA
    Does it have ammonia in it? The Navy may have been right. They usually were, and picky about their airplanes too! :eek:
    pigpen
  16. polisher
    polisher
    Alliance Vendor
    Most polishes and cleaners that contain ammoniates or any other form of anhydrous have been banned in military and federally funded establishments for some time.
    It just takes a long time to trickle down to ground level.
    Any form of anhydrous is also banned on airframes and any airframe structure or securing system that contains Zinc.
    Which is how aircraft stripper came about.
  17. Mother's Mag Cleaner..................I think it's muriatic acid.
  18. Paul
    Paul
    Editor
    polisher,
    so, what please is the answer to this question?
    I have not found anything that will clean an aluminum manifold to new as-cast cleanliness, nuttin.
    is it possible?
  19. magnet
    magnet
    I second the motion on Aluminum Mag cleaner.. some eagle one.. may be a bit abrasive but it will strip the corrosion off that manifold.. a little bit of paint off the rocker covers but what heck.. your probably gonna paint em anyway... right?
  20. Turbo26T
    Turbo26T
  21. As far as I know it doesn't contain ammonia.It was being used extensively in the Navy when I was in(64-67)and yes I was a,"BB Stacker".
  22. pigpen
    pigpen
    from TX USA
    I was in from '63 to '84. I seem to remember that they banned the WD sometime in the '70's. Forget about the corrosion. Lets go bomb somebody!(Check out www.vf-114.org) :)
    pigpen
  23. Those F-4 pics bring back a few memories.The outfit I was in was the All Services Evaluation Group stationed in Patuxent River.About half of our aircraft were Phantoms(F-4A#13,F-4B's and two F-4G Data Link birds)as well as a couple F-8's,A-4's,an A-6 and A-7,OV-1 and OV-10 and several helos).We did mostly weapons systems evaluations although there were several other projects having to do with radar reflections(stealth)and spin recovery techniques.Worked a lot with guys from Wright Pat and China Lake as well as civilian engineers.An interesting time in my life.
  24. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Dupont metal prep.....It's for steel but works great on aluminum if you use one of those little br*** brushes....Make sure to rinse off with water before it dries......
  25. LOST ANGEL
    LOST ANGEL
    Back to the top for a difinitive answer!!! Thanx.-MIKE:p :D
  26. pigpen
    pigpen
    from TX USA
    I did two different tours at NAS Pt Mugu, part of the Pacific Missle Range. Also velley interestink. Also had to work with Sand Crabs sometimes. One supervisor from Raytheon was queer as a three dollar bill. Gives new meaning to the phrase "Watch Your ***"! :D
    pigpen
  27. polisher
    polisher
    Alliance Vendor
    There's not really a cleaner that removes corrosion unless it's a decent polish.
    And to ne honest, 95% of them are a waste of money.
    If you just want to clean it up 00 wire wool will probably do the job in this instance as well as anything.
    Maybe us a little WD40 on it to make it slip and give the aluminum a nice sheen.
    That's about the fastest and easiest way to get a finish.
    The WD40 will tend to make it gather dust though.
    I use my metal polish and restorer with wire wool on real cruddy aluminum.
    If I can't use my tools on it.
    Sometimes it can be easier and more of what you want if you don't want to go crazy and really polish it.
  28. pigpen
    pigpen
    from TX USA
    I've used regular oven cleaner on motorcycle engines with decent results. (And no ill effects by the way) Also, there used to be a product out called Aluminum Jelly that worked pretty well. It was made by the same company that made/makes Naval Jelly but didn't work real well on navels, only aluminum. :D
    pigpen
    I just did a search. Aluminum jelly is still avialable. See www.loc***eproducts.com
  29. Paul
    Paul
    Editor
    so I thought I would test a few of these suggestions,
    the Aluminum Jelly was not very effective
    niether was the oven cleaner, carb cleaner, metal prep or soap and water
    best results while not what I would hope for was at least what Bob was asking for, to "freshen up a bit" was with mag wheel cleaner for rough cast wheels.
    followed the directions, lather, rinse, repeat.
  30. Paul
    Paul
    Editor
    I took a chance and used it on this distributor, being carefull not to get it inside, rinsed it well and dried it real good..
