Hot Rods Cleaning aluminum for welding
Discussion in 'The Hokey Ass Message Board' started by 24 Dodge, May 8, 2016.
  1. 24 Dodge
    24 Dodge
    What is best used to clean aluminum for tig welding, I mean grease and oil. Thanks in advance Mike
  2. oj
    oj
    I use GumOut 2+2 carb cleaner, it cuts the oil etc and dries quickly to make it safe when welding. I also use scotchbrite pads on an angle die grinder on the difficult stuff befor carb cleaner. There are horror stories using carb cleaner when welding, the fumes cause brain damage so be sure you use high quality cleaner that evaporates quick. A br*** tootbrush style wire brush is handy too, the stainless ones can contaminate the weld.
    Joliet Jake likes this.
  3. dirt t
    dirt t
    I use acetone and a stainless brush that I only use for aluminum .
    Go to a site called weld****ers.com they are also on u tube.
  4. big duece
    big duece
    from kansas
    Just use the non-chlorinated type brake clean or acetone.
    blowby likes this.
  5. deathrowdave
    deathrowdave
    from NKy
    Be cautious , because you could harm yourself and family members . I use simply green
  6. Rex_A_Lott
    Rex_A_Lott
    I use wheel and grille cleaner, it is a mild acid. Rinse with water and then use IPA. Good Luck
  7. dirty old man
    dirty old man
    ^^^^^^^^^^^^ What is "IPA"?
  8. AVater
    AVater
    India pale ale?
  9. dirty old man
    dirty old man
    We think alike, I almost posted that as part of my question, LOL!
    AVater likes this.
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I while down everything (even the rods) with rubbing alcohol immediately before welding aluminum.
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    Old aluminum over the years will corrode and the worst part it's very porous and soaks oil deep into it. Regardless how well you clean aluminum heating it will draw more impurities.
  12. dirty old man
    dirty old man
    True words here. In years past I had a boat propeller repair shop. Many aluminum props when welded to repair edge damage would have pits appear in the parent metal, just adjacent to the welded area.
    These were cast aluminum, with the Volvo inboard/outboard props by far the worst . Sheet, or plate aluminum not as bad with these pits.
  13. nmpontiac
    nmpontiac
    from Taos, NM
    Are you welding sheet material or cast stuff? Petejoe is right about the cast aluminum stuff - it's amazing how much **** floats out of it - If you're going to grind the welds down afterwards, "V" the weld area, use plenty of amps to float the **** to the surface, and clean it with acetone before welding. Sheet stuff I usually hit with a scotchbrite disc, clean with acetone. The selection of filler material will certainly affect the appearance and cleanliness of the puddle, try to match it with the base material - there's lots of information out there as to what filler to use with what base material.
  14. Marty Strode
    Marty Strode
    I clean with lacquer thinner, if it's a casting I sometimes p*** a propane torch over the area prior to welding. That way you can bring any impurities to the surface, and wire brush for a final cleaning before welding.
  15. 24 Dodge
    24 Dodge
    I like the IPA after welding. Thanks everyone who responded.
  16. The37Kid
    The37Kid
  17. AVater
    AVater
    Ok, so what is IPA?
  18. chevyfordman
    chevyfordman
    India Pale Ale, my favorite
  19. Ebbsspeed
    Ebbsspeed
    IPA = In Process ***urance, real-time weld quality monitoring.
  20. AVater
    AVater
  21. tfeverfred
    tfeverfred
    Lincoln recommends:
    Base-metal preparation:
    To weld aluminum, operators must take care to clean the base material and remove any aluminum oxide and hydrocarbon contamination from oils or cutting solvents. Aluminum oxide on the surface of the material melts at 3,700 F while the base-material aluminum underneath will melt at 1,200 F. Therefore, leaving any oxide on the surface of the base material will inhibit penetration of the filler metal into the workpiece. To remove aluminum oxides, use a stainless-steel bristle wire brush or solvents and etching solutions. When using a stainless-steel brush, brush only in one direction. Take care to not brush too roughly: rough brushing can further imbed the oxides in the work piece. Also, use the brush only on aluminum work-don't clean aluminum with a brush that's been used on stainless or carbon steel. When using chemical etching solutions, make sure to remove them from the work before welding. To minimize the risk of hydrocarbons from oils or cutting solvents entering the weld, remove them with a degreaser. Check that the degreaser does not contain any hydrocarbons.
  22. Rex_A_Lott
    Rex_A_Lott
    India Pale Ale is what you soak your head in to get rid of the jitters if you need it. IsoPropyl Alcohol is a good cleaner. Good Luck
  23. Dapostman
    Dapostman
    There is a very good tutorial for welding cast aluminum on you tube by Jim Bollinger at DoRite Fabrication. He is an instructor for Lincoln Welding, and also runs a job shop… Making it easy to find the ***le is Welding a cast aluminum part….
