Cleaning An Aluminum Intake Manifold
Discussion in 'The Hokey Ass Message Board' started by Madnomad, Sep 20, 2012.
  1. I have an old Edelbrock C4B that I am using on my '64 El Camino build. I am trying to go period correct late '60s. Does anyone know a good way short of media blasting to clean it? It hasn't been used in over 25 years and is dirty and darkened with age..
    Thanks,
  2. I just use plain old glass beads...pummells the metal, closes the pores and stays satin silver forever..at least mine did.
  3. HotRodFreak
    HotRodFreak
    Try oven cleaner but don't leave it on too long.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Glass beading is really a good way to clean it, and I have shot clear over it later to seal it and make it easier to keep clean, but that is a personal preference.
    Don
  5. 19Fordy
    19Fordy
    If you have ever used oven cleaner on an aluminum cooking pot, you will never want to use it on your manifold.
  6. slammed
    slammed
    That (baking) soda blasting is a do-it-yourself method. Degrease it, carb spay (Berrmans) then soda blast, if glass beading is not available to you.
  7. 3quarter32
    3quarter32
    If you have a way to cook it in antifreeze at about 220 degrees for 24 hours, it will come out looking like new. Don't reuse whatever you cook it in again except for that purpose. Surely don't cook food in it or let the pets drink out of it.
  8. n847
    n847
    I agree with Don! But remember to cover/plug any openings and you can never flush the thing enough you don't want those bits of anything floating around in your water jackets, pumps, oil, etc.!
    However I do think that when you said "Does anyone know a good way short of media blasting to clean it?" that you didn't have access to any form of blasting, including glass.
    I tried for a while to clean mine in several different ways, and finally I just broke down and asked around till I found a buddy with a Harbor Freight sand blaster, and I bought him a bucket of glass beads and we knocked it out! I'd say you should be able to find someone willing to glass bead it for you for 20-30 dollars!
  9. Brad54
    Brad54
    from Atl Ga
    The problem with glass beading is that it opens the pores of aluminum, and you end up with a white luster.
    Depending on how much you want to spend, Lamar Walden in Doraville, Georgia as a "reskinning" process (and he can repair any damage and re-machine all the surfaces to an NOS finished piece) that burnishes the pores closed and gives it a natural, fresh-cast finish. It also won't absorb grease or gas, so you can simply wipe it clean again.
    Here's a 409 intake we restored for a story. I masked it down the middle, and glass-bead blasted the driver's side, and did his reskinning process on the passenger side (bottom half, as oriented in picture).
    Short of sending it out, your next best bet might be to clean with mag wheel cleaner and then run over it with low-speed brass wire wheels (mounted in a drill). I did that with a set of finned drums, and it works well.
    However, I don't know of any arbor-mounted brass wire wheels small enough to get into the nooks and crannies of an intake.
    -Brad
  10. harpo1313
    harpo1313
    from wareham,ma
    sounds strange but brake fluid and a brass brush works for me.
  11. I cleaned the inside of a rusted oil pan by filling it with Pepsi ( or Coke ) and leaving it overnite. I've also used muriatic acid, outside with rubber gloves, resperator and face shield. Nasty stuff but it really works.
  12. Pooch
    Pooch
    from Oklahoma
    I have a tumbler.
  13. i glass bead them for people quite often. if you spend enough time going over and over it. it will look like it came out of the box new. do not sand blast it. it will look like you painted it gray.
  14. i've used white vinegar to clean rusty parts, that may work here also, submerge it for a few days. i'd do a test piece first though.
  15. trashn'l
    trashn'l
    NAPA has an aluminum cleaner that works good. Used it to clean the cases on my Shovelhead and they look like new without the white look.
  16. chinarus
    chinarus
    from Georgia
    Probably not an issue with an intake but consider carefully whatever process you use.
    I had a VW engine case I had bead blasted once to make it "purdy"
    and never did get all the crap out of the inside.
    Locked up the rebuilt motor within 2 minutes and I
    Gave up after replacing new bearings 3 times.
  17. Brand Apart
    Brand Apart
    from Roswell GA
    already been said but Lamar walden's shop does bad assssss work. The re-skining is so cool.
    Even though they are Chevy Gods they are doing a 354 hemi for me right now. I've been able to stop by the shop on several occasions and am always amazed at the quality stuff they do.
  18. 39 Ford
    39 Ford
    I have a 1967 Wieand manifold that I cleaned with someones glass beader and scrubed very carefully afterwards. I then sprayed it with clear engine enamel looks great.
    I am sure you can find someone with a glass bead cabinet, ask around most repair shops have them.
  19. stuart in mn
    stuart in mn
    I've used this stuff myself and it works well. spray it on, let it soak a little, scrub with an old toothbrush, then rise off with water. It's nasty stuff, so wear gloves and eye protection, and use it with plenty of ventilation.
  20. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Spray it with Simple Green, scrub it, then powerwash it.
  21. Used "Oil Eater" from Costco and then scrubbed it with "Bar Keepers Friend" cleanser and a pot scrubber. Looks almost new. Just a few "age" spots on it. I may soda blast it yet, but it looks great. Thanks for all of the replies and suggestions.
    Oil Eater is great. mix it 4-1 and degreased the engine compartment and old engine. Spray it on and you can see it working almost immediately and it's enviromentally friendly too.
  22. maybelene
    maybelene
    Several years ago I went to a boat supply place and got some stuff they spray on pontoons to clean them and it seemed to work well, but i can't remember what it was called. Worked pretty well on some old aluminum slotted wheels too. Had a good bit left over though.
  23. HamD
    HamD
    Has anyone else had luck with baking aluminum castings to get the greases and oils out?
    I'll probably end up trying this. Should I boil it on the stovetop or bake it in the oven? Any risks of vapors?
    It may not go over as well as the use of the dishwasher for similar goals. (head was shaking, then she went back to bed. :D)
  24. Dale Fairfax
    Dale Fairfax
    This sounds very much like steel shot blasting. I had a Flathead intake done that way in an industrial machine shop and it literally looked like new-didn't have that satin white look as does bead blasting. Then I made the mistake of clearcoating it-it turned gray.
  25. FANTASY FACTORY
    FANTASY FACTORY
    Take a stroll down to your local HVAC supply house and pick up a gal of coil cleaner.
    I use 1 gt in a 15 gal poly barrel of tap warm water, let soak overnight, rinse with cool water, DONE. not clean enough yet, add another quart and let it go around again.
  26. we have this stuff at work thats made for cleaning aluminium wheels, called ally king (green shit that smells funky as) it works awesome. i used it to clean the brake calipers on my mates o/t project and they came out like brand new. be warned tho it's harsh stuff so you need gloves, eye protection and a mask.
  27. R Frederick
    R Frederick
    from illinois
    I buy that by the gallon and use it on all my aluminum. It's a pretty strong acid that will etch the intake clean.
  28. jimbousman
    jimbousman
    Soda or Walnut blasting does a nice job. Chemically, Iv'e boiled manifolds in lemon juice and water with some good results. I've also used Castrol purple cleaner then spray it with satin clear urethane.
  29. Blue One
    Blue One
    from Alberta
