Hot Rods Cleaning bed wood
Discussion in 'The Hokey Ass Message Board' started by 63401nailhead, Jun 2, 2024.
  1. 63401nailhead
    63401nailhead
    I got some overspray on my truck bed wood. I forget what I originally used on the wood to finish it, some kind of varnish or sealer. What could I use to clean off the overspray that won’t damage the finish on the bed wood?
  2. If the overspray is fresh, WD-40 may do the trick.
  3. ronzmtrwrx
    ronzmtrwrx
    I would try a clay bar and Windex if the finish is pretty smooth.
  4. Budget36
    Budget36
    Not an expert nor do I have experience with this, but isn’t varnish a layer on top vs a stain that soaks into the material?
    If there’s a “top layer” then seek something that might work with that.
    If a stain was done, maybe steel wool and reapply some stain that would match if needed?
  5. tim troutman
    tim troutman
    clay bar sounds like solid idea you might try a magic eraser
  6. 63401nailhead
    63401nailhead
    Update- the clay bar worked perfectly, thanks!
  7. CLEANING BED WOOD
    Yikes :eek: I think you may be on the wrong site for that question o_O
    '28phonebooth likes this.
  8. A sidestep here, but your comment reminds me of the older guy that slaps his wife on the *** and says:
    "Come on Honey, I've got my semi-annual hard-on."
    She says: "Don't you mean your annual semi-hardon?"
    Well, I thought that was funny....YMMV!
    borntoloze and Budget36 like this.
