Projects Cleaning Rusty Chrome
Discussion in 'The Hokey Ass Message Board' started by TheSteamDocII, Mar 6, 2026.
  1. TheSteamDocII
    TheSteamDocII
    I have a shifter that's corroded with surface rust. It's a chrome plated piece. How can I polish it back to chrome? It's not something that can be easily replaced.
  2. Try a little CLR and mild scotch bright pad
    Then polish
  3. 51504bat
    51504bat
    When I was a kid we used Coke and aluminum foil on surface rust on our bike rims.
    dana barlow and leon bee like this.
  4. leon bee
    leon bee
    ^^^ Yeah, coca cola and aluminum foil was always a favorite method in motorcycle lore. It is an interesting approach.
    51504bat likes this.
  5. 57Fury440
    57Fury440
    Yes the aluminum foil thing works, but I think you only need to use water with it.
  6. willys36
    willys36
    Dupont #7 polish works like a champ. It is co**** enough to wipe away the red haze with a couple swipes, gentle enough to leave polished chrome. Follow with a coat of Turtle paste wax and near like new.
    lostn51 likes this.
  7. 57JoeFoMoPar
    57JoeFoMoPar
    Noxon from the grocery store does a great job on chrome. Ammonia based. Put some wax on it after to protect it
  8. pantodd74
    pantodd74
    NeverDull is also good to use.
  9. slowmotion
    slowmotion
  10. pirate
    pirate
    from Alabama
    I got some rusted sockets and wrench’s from an estate sale and let them soak overnight in a mild concentration of citric acid. In the morning wire brushed them with soft wire br*** brush and they came clean and bright. White vinegar will als remove rust without damage to the chrome.
  11. primed34
    primed34
    Tinfoil and Windex. I've also had good luck with Zephyr polish.
  12. Bugguts
    Bugguts
    I found a chrome 4 speed shifter in our machine shed on the farm. No one knew where it came from and it was rusted badly and would not move at all. I soaked it in citric acid for a couple days, rinsed well and BAM! It shifted like new, and looked good. Found out it was a mid 60s Corvette shifter.
  13. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    from Pryor, OK
    I've used tin foil and WD40 with decent results
  14. lostn51
    lostn51
    from Tennessee
    Naval Jelly if you can find it
  15. TheSteamDocII
    TheSteamDocII
    I'll give these a try. Thank you everyone.
  16. Kiwi 4d
    Kiwi 4d
    Dr Pepper and tin foil works great for me ,didn’t have any coke on hand.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    how about a picture of the part you are wanting to clean?
  18. Doublepumper
    Doublepumper
    from OR-WA, USA
    Trick is to not scratch the chrome with the rust you're trying to remove. My favorite method is to use oxalic acid to remove the rust. Then treat the part with Ospho, then do a foil rub to fill the pits, then a polish and wax.
    CURIOUS RASH likes this.
  19. noboD
    noboD
    X2. Only thing I use on chrome. NEVER use steel wool.
  20. 29Sleeper
    29Sleeper
    from SoCal
  21. HOTRODPRIMER
    HOTRODPRIMER
    I used CLR, tin Foil and lemon juice , navel jelly, br***o and everything people suggested with lackluster results on the bumper of my '50 Ford Coupe.
    After I gave up Brenda suggested steel wool, I figured what have I got to loose, it would probably scratch it up but you don't know if you don't try, I started with #1 steel wool and went back with #0000 steel wool, not perfect but a whole lot better, at this stage I was not finished I gust worked the top of the bumper first.
    BTW, I spent several evenings getting it to this point. HRP
  22. Well worth the effort!!
