Cleaning whitewalls?
Discussion in 'The Hokey Ass Message Board' started by rockabillybassman, Sep 19, 2005.
  1. What's the skinny on restoring and cleaning whitewalls? Any hot tips?
  2. stickylifter
    stickylifter
    from Detroit
    Bleache White tire cleaner is great stuff. You can get it at Murray's/Auto Zone.
  3. Alfster
    Alfster
    Are you running skinny white walls? I have found the best way to clean them is with a household detergent or even something like Solvol.
    You are from Cambridge aren't you? We should get in touch sometime.
    email me at alfster@xtra.co.nz or 8234100 - Ian -
  4. Coupe-De-CAB
    Coupe-De-CAB
    from Nor Cal
    I used good 'ol 409 cleaner and a white shop rag. Brightened them right up:)
    takes alot of pressure and alot of scrubbing!
    CAB
  5. stickylifter
    stickylifter
    from Detroit
    Waitaminnit! Seems I've been doing it the ghetto way. After a quick search, I came up with this:
    19. How is the best way to clean my whitewalls?
    It is best to clean your whitewalls with our Wide White Tire Cleaner. We have spent the last year developing this specifically for our tires. If you do not wish to use this it is best to use mild car wash soap and some type of Scotch Brite pad.
    20. Can I use bleach white to clean my whitewalls?
    Absolutely not. Bleach white is the leading killer of whitewall tires. This robs the tire of valuable oil and moisture that it needs and the tire will appear to have cracks in the sidewall after a few uses of bleach white. The same thing would happen if you cleaned your favorite shirt with bleach on a regular basis. If you have tough stains on your whitewall, we recommend mild car wash soap and some 600-1000 grit sandpaper.
  6. jdubbya
    jdubbya
    After you clean them, mop-n-glow seems to seal them from dirt and grime quite well. I was getting tired of wiping them off all the time, and ending up with dirty streaks, so I took the suggestion of mop-n-glow, from a fellow HAMBer, and it has been working fine for a few weeks now, and all you have to do is dust them off every once in awhile after you apply it. I just poured some on a rag, and treated the tires the same way you would with armour-all.
    Fabulous50's likes this.
  7. I've been using Castrol Super Clean and little br*** bristle BBQ brush for years..works mint...then wash them with wateva carwash/wax mix your using.
    Caution...dont get the SuperClean on paint...it dont like it..:)
    Thats if ya got paint !! :):)
  8. chuckspeed
    chuckspeed
    I buy Bleche Wite by the gallon - it's good stuff for keeping whitewalls white. It's not bleach, BTW; just a very caustic solvent.
    Best way to 'restore' old whites to some sort of not-so-yellow finish is a LOT of elbow grease with a Brillo or SOS pad. The combination of steel wool and soap removes both dirt and oxidization; if the WW's are still fairly pliant - then you'll get back a loth of the whiteness.
    If your WW's are more than ten years old, tho - fuggedabou***. They're whatever color they are.
  9. screwtheman
    screwtheman
    Brillo pads. The kind with the detergent impregnated in them. :cool:
    Bob Lowry and Just Gary like this.
  10. leadsled01
    leadsled01
    I told you that works well..
  11. RenoRat
    RenoRat
    from Oxnard,Ca
    westleys white wall bleach its in a spray bottle and it works the best if you use a semi soft scrub brush it will take out BIG scuffs!!!
  12. Digger_Dave
    Digger_Dave
    One product that I have used for years on tires - and white walls - is Knight's "Spray Nine."
    Spray on, scrub with a stiff bristle brush; then rinse with clear water.
  13. Scrap Heap
    Scrap Heap
    The brillo and sos pads do work, I've also been told, but haven't tried it, a fine grit sand paper, 400 or finer.
  14. RonC
    RonC
    from Montebello
    I like Super clean too cause it does a pretty good job and I can use it for a whole bunch of other stuff. I was cleaning up an old amp that I just bought and my bottle disappeared. My wife had it and was using it to clean something in the kitchen.
  15. McQueen
    McQueen
    Bingo! I've used Brillo for years. They work like a charm. In a pinch, I just wet some fine-to-medium grade steel wool and squirt some Simple Green on it.
    cheers!
  16. chuckspeed
    chuckspeed
    Jim - I completely agree with you. The comment on Brillo or SOS pads is a resto tactic on yellowed rubber; Bleche Wite does not bring back an oxidized surface - but works great on regular rubber!
  17. JimC
    JimC
    from W.C.,Mo.
    I axccidentally deleted my original post. I was having trouble with posting photos showing tires that had about 28,000 miles on them.
    They were on my 62 when it won detailing awards at Statbvird shows, and they were on it when it garnered a Custom Rodder "Top Ten Pick.
    I have been able to clean them with Westley's Bleach White and a spray bottle.
    Jim
  18. Brandy
    Brandy
    from Texas
    Gosh you boys and your fancy methods. I just use Comet or Ajax, a bucket of water and a scrub brush with LOTS of elbow grease. Hey cheap shampoo cuts dirt/grime/grease without ruining paint!;)
    **x
  19. Spray on Degreaser,rinse and then wash with soap while doing the rest of the car. No scrubbing needed :)
  20. bills model a
    bills model a
    no way man the steel in the pads will rust the white
    and then you have rust walls
  21. rockable
    rockable
    The whitewalls on my Tin Woody were getting brown looking, so I tried a different approach to cleaning them. It turns out that 400 grit wet sandpaper with soapy water will remove the brown oxidized rubber and leave you with like new whitewalls. Try it!
  22. WalkerMD
    WalkerMD
    I’ve been using SOS pads all my life and have never had a problem. Takes a good rinse afterwards to remove the soap tho.
  23. woodiewagon46
    woodiewagon46
    from New York
    Westley's White Wall cleaner and a soft bristle brush, works great for me. I also use those Mr. Clean eraser pads for a quick clean up.
    rockable likes this.
  24. Bandit Billy
    Bandit Billy
    Nice tip. I purchased a new set of Auburn WW's and the instruction card very prominently in 14 point print said NO BLEACH PRODUCTS!
    Also, no armor all. A lot of tire shines are like floor polish, they tend to build up and brown the side walls (and shiny sidewalls look a bit like merde on a hot rod anyway). You sanded all that wax/silicone build up away. Now make sure it doesn't come back. BTW, Diamond back recommended SOS pads or the equivalent for clean up. And just FYI, I use Harley Davidson Wheel and Tire spay on the tires on my roadster. Not shiny, just clean and road dirt doesn't cling to them.
    I have used Wesley's for years but I think the new rubber formulas are not playing nice with the bleach white.
    rockable and Joe Blow like this.
  25. Lone Star Mopar
    Lone Star Mopar
    Try a "magic eraser" with a few drops of Dawn dish soap and water. Works like a champ, I buy the off brand dollar store version.
    kadillackid and rockable like this.
  26. Joe Blow
    Joe Blow
    Firm believer in SOS pads too.......have used them forever. Protect with this, to keep the brown at bay....never found anything better.
    WalkerMD and rockable like this.
  27. krylon32
    krylon32
    from Nebraska
    The guys at Diamond Back suggested Simple Green which I am now using and it works great.
    Bandit Billy likes this.
  28. Fortunateson
    Fortunateson
    Where do you get that stuff?
  29. Joe Blow
    Joe Blow
    Several online places carry it....I get mine thru Amazon (Prime free shipping).
  30. stanlow69
    stanlow69
    Use the bathroom cleaner Scrub-N-Bubbles. I have been using it for 25 years. No sos pad required. The Wesley`s Bleach White puts spots on my hubcaps which are a pain to come off. Never liked that product. You need to use rubber gloves after using this product, unless you want your hands to smell like bleach all day.
