Clear coat? Quick fix?
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Apr 7, 2010.
  1. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    When it gets wet, it goes away. :cool:
    Easy fix?
  2. HomemadeHardtop57
    HomemadeHardtop57
    I think you're probably going to have to respray the whole thing. You could scuff it up and try to blend in the area to the rest, but I'm sure it would never match. But then if you do that..the newly painted trunk wouldn't match the rest of the car..humm
  3. davidwilson
    davidwilson
    from Tennessee
    semi gloss clear spray bomb - shoot just the spot that's turned white
  4. Stu D Baker
    Stu D Baker
    from Illinois
    The clearcoat has deteriorated and is delaminated. This has exposed the base color. Any repair is only going to be as good as the foundation it's applied to.
    That being said, do you really think painting over an existing problem surface is the best thing? I would think strip the panel and refinish as needed. Other methods might only be a "band aid" fix. If you're going to keep the car, do it once. Good luck Stu
  5. SlowandLow63
    SlowandLow63
    from Central NJ
    Yep, two ways out. One is right and the other is quick.
  6. chopolds
    chopolds
    from howell, nj
    Once the clear disappears, like yours did, it lets moisture get into the basecoat, which is porous paint. If you do not live in a very dry area, there's probably rust under that blue paint where the clear is gone. Spreads quickly, too!
  7. gmartin73
    gmartin73
    the only fix is to strip it down and repaint it.
  8. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Did you try to buff and wax
  9. blt2go
    blt2go
    sorry to say, the only fix is to repaint and clear the entire hood and blend paint to the left fender and clear it also.
  10. Captain Freedom
    Captain Freedom
    from Upstate SC
    Put a racing stripe down that side.
