Clear over 1 Shot
Discussion in 'The Hokey Ass Message Board' started by kool 52, Jan 24, 2012.
  1. kool 52
    kool 52
    G'Day All,I have been told conflicting info,Can you 2 pac Clear over 1 Shot enamel.Thanks for any advise you give.
    Cheers Mark
  2. dirtfan50
    dirtfan50
    from Kentucky
    I have seen it done several times at work but we use PPG products. Im not sure about the 2 pack clears
  3. SinisterCustom
    SinisterCustom
    Whats 2 pac clear?
    For best results...add a "tad" bit of the clear hardener in the 1-shot.....reduces the risk of bleed through...
  4. XXL__
    XXL__
  5. dirtfan50
    dirtfan50
    from Kentucky
    Why did I see that coming ^^^^
  6. only if you add a little hardner to the One Shot. or use the urathain striping paint for perfect results
  7. Rich Wright
    Rich Wright
    I clear over 1- shot all the time with Urethane without adding anything to it. I just let the solvents dry out thouroughly before clearing.
    I used to add a drop or two of hardener to the 1-shot but it really didn't make any difference. Certain colors have a tendency to bleed if your not very carefull and it doesn't matter whether there is hardener added or not.
  8. *Kendall*
    *Kendall*
    from chicago
    I clear over 1 shot all the time also I just let it sit fora week in a nice warm place or I take to my Buddyss shop and he bakes it in the Booth then let it cool then bake it again thencool once. More and I don't have any problems
  9. AG F/C
    AG F/C
    Good clear adhesion is acheived if you apply the clear while the base is allowed to just tack off.
    May be different if your base in non compatible. I maybe missreading somthing. Of not understanding a one shot.
  10. Rich Wright
    Rich Wright
    Usually what I clear has been thoroughly dried out and color sanded, then pinstriped which is allowed to dry thoroughly, then cleared.
    I did an experiment on one of my tractors years ago which included clearing over 1-shot, then using it as intended.... Serious abuse and weather extremes, washing it off once a year with engine cleaner, etc, etc..... Took 7.5 years before any delaminate on occurred....and that was over the 1-shot. I couldn't ask for more durability than that.
