Technical Clearance question
Discussion in 'Traditional Hot Rods' started by dsiddons, Apr 21, 2026 at 11:25 AM.
  1. dsiddons
    dsiddons
    from Indiana
    How much clearance is recommended between top of the rears and fenders ?
    Jalopy Joker likes this.
  2. woodiewagon46
    woodiewagon46
    from New York
    I don't know if there is a "recommended" clearance. It all depends on your spring rate and ride height. I have seen some tires that look like they would rub, but don't seem to have an issue.
    19Eddy30 likes this.
  3. squirrel
    1" clearance when the rear of the car is hitting the bump stops. Or the axle hits the frame, or whatever else you have instead of bump stops :)
  4. Jalopy Joker
    Jalopy Joker
    correct clearance is when hit a big dip, or hole, in road and ride does not bottom out. frame cracks due impact not worth the cool look.
    dsiddons likes this.
  5. alchemy
    alchemy
    Looks good to me.
  6. dsiddons
    dsiddons
    from Indiana
    These are great suggestions. Hahahaha I’m gonna use the spring seat . That should make up for some ride hight.
  7. dsiddons
    dsiddons
    from Indiana
    Hahahaha no **** right!?! I see some great examples and think if that’s even possible. Maybe raise it an inch or so.
