Customs Cleveland to windsor
Discussion in 'The Hokey Ass Message Board' started by Olly_, Jul 27, 2014.
  1. Olly_
    Olly_
    from Australia
    Hey guys newbie here. just after some advise my 351cleveland had big end failure in my F100. it was really tired anyway so its a good excuse for an upgrade. ive been looking at crate engines i am wondering if engine mounts,power steering, alt. pulley brackets,exhaust bolt up to a windsor, have not had much to do with them. cheers olly
  2. I have not mucked with Ford motors for 30 years, I don't thing it will line up that well.
    Are you looking at using a 302 or 351 Windsor as even these two are different. Maybe some OHV Ford guys can give you the right info to get you going.
    Oh and welcome. JW:)
  3. Olly_
    Olly_
    from Australia
    thanks for that. I was looking at a 427 stroker (351 block.) a windsors just alot cheaper. but wanted to see if i could swap some of the parts over from a clevo or not.
  4. X38
    X38
    Engine mounts are OK, that's about it.
  5. Marv64
    Marv64
    The Cleveland and Windsor have different bell housing bolt patterns. Hope this helps.
  6. bartikus
    bartikus
    No the Cleveland and the Windsor have the same bell housing. Its the modified that has the big block bell. I personally think the Windsor is a better motor. It fits a little better and has better aftermarket support because it was built for around 25 years on the other hand the Cleveland was only built for 4 years.
  7. X38
    X38
    [QUOTE It fits a little better and has better aftermarket support because it was built for around 25 years on the other hand the Cleveland was only built for 4 years[/QUOTE]
    OP is in Australia and we had them up to the mid 80's (Clevelands), including F trucks.
  8. OP is in Australia and we had them up to the mid 80's (Clevelands), including F trucks.[/QUOTE]
    Yip and Australia had a 302 Clevo as well which was never available in the States, think the Cleveland came out in the XW falcon in 1970 and finished in the XF in about 1986?
  9. X38
    X38
    Started with XY Falcon and ZD Fairlaine and F trucks. Lots of tow trucks.
  10. George
    George
    The C is to Oz what the SBC is to the US.
