1952-59 Ford Clifford headers for the Ford 215 - 223
Discussion in 'Off Topic Hot Rods & Customs' started by ascenttm, Dec 6, 2009.
  1. ascenttm
    ascenttm
    from HERE
    Got a set of Clifford headers for the 215
    Clifford says they'll fit 52 to 64 but They are way off
    from their site
    car headers
    Truck headers
    Truck headers look like a better fit for the 52 and 53 - those years had the front cross-member!
    They even got the engine sizs wrong - Ford did't make a 216 - might be the reason they show them next to a Chevy block and the wrong side
    53-0030 "6=8 HEADERS" Ford 216-223-262 Car 1952-64
    Code: 53-0030
    Price: $359.00
    Anyway I have a set that are ceramic coated - I got them mounted after cutting into the crossmember about 3" and cutting the collector flanges off - still needs some more t******* but they are mounted-
    don't know how these would fit the 223 or the 262 because the rear header hit the block where the bell-housing mounted - so I cut the collector flange on the rear and ground about 1/4" off the block [​IMG]
    Now I need to make some type of mount for the clutch linkage or change over to hydraulic clutch - and box in the cross-member, I do have to make a motor-mount because I cut out where the original one was - and I need to wash the engine, but that'll have to wait till warmer weather- all the oil is just from a valve cover leak.
  2. ascenttm
    ascenttm
    from HERE
    I tried to make a set of Patriot truck headers fit but I made a mess of those - pretty much have to use the flanges and start from scratch.
    I do have a Huth pipe bender and over the winter I hope to make some more tooling for some smaller pipe and I'd still like to make a set that would be a bolt on for the 215.
    I've got the clifford intake and a Vintage Speed tri power adapter with three Holly 94's mounted. You think I'll be able to feed the inline 6 enough fuel!:D
