Clipping a 49 Chevy sedan
Discussion in 'The Hokey Ass Message Board' started by AA/Fuel34fordpu, Dec 22, 2010.
  1. rusty1
    rusty1
  2. Greezeball
    Greezeball
    ....a lot of guys try to use clips with disc brakes which are wider or the next generation Nova clips which ARE too wide.
    [​IMG][/QUOTE]
    Glad someone mentioned this. One frontend choice I haven't seen in a long time is a AMC Pacer. Is this because there is few of them left? The frontend unbolts from the Pacer and GM discs pop right on to the spindles. A friend put one in a 47/48 Chev years ago was a piece of cake.
  3. Greezeball
    Greezeball
    Oh ya mine has MII and it works great. Would like a power rack for it though. Previous owner had this front end installed at a chasis builder.
  4. another option, since the reason for the original post was his was "ALL HACKED UP" 16 bolts and the whole front suspension drops out. with all the others switching to Mll and camaro/s10 clips you should be able to come up with a free one (I did) 300 bucks for a rebuild kit and a couple hundred (later if you like) for a disc brake conversion. new gas shocks and radial tires and it will drive as good as all the others.
    I'm an old **** and this is just an opinion......Jim
  5. aw1950
    aw1950
  6. fbama73
    fbama73
    Google "Mustang II suspension failure" before buying any parts- some of the stuff available is downright dangerous. Not all of it, though.
  7. Yes, just unbolt the damn thing and put another one in there. You can probably score one for free, or for s**** weight, hell I s****ped one a few months ago. Try and get a 51-54 front end if you can, saves you the h***le of putting the Bendix brakes on it.
    Next best alternative is the 85-back Jaguar XJ, because here again, you can generally score the donor car for close to s**** money, part out some of it and come out ahead.
    Camaro/Firebird and Monte Carlo are all too wide, S10 borders on too narrow. And let's not even get into mixing and matching frame rail designs at the firewall (yeah, that's going to be great in a collision).
  8. 53sled
    53sled
    from KCMO
    nobody makes replacement parts anymore.
  9. gsport
    gsport
    here's a list i found of different widths of donor cars and old cars too....
    The first gen camaro is slightly narrower than the second gen (70 - 82). First gen is 60 on the rear and approx. 60 1/2 on the front, which is almost exactly the same as your 50. This measurement is mounting surface to mounting surface (outside hub). The second gen is 61 1/2 on the front and 60 1/2 on the rear, mounting surface to mounting surface. Scroll down near the bottom of the info below and you'll find some clip measurements.
    Original Vehicles
    Rear Suspension Width (Flange to Flange)
    Year
    Cl***ic Vehicles
    Width
    26-39
    Plymouth-Dodge car/pick up
    56-58"
    40-52
    Plymouth-Dodge car
    60-62"
    26-39
    Chrysler/DeSoto Car
    60"
    Most Early
    Mopar's
    56-62"
    25-39
    Chevy Car
    56-58"
    26-46
    Chevy Truck
    56-58"
    40-48
    Chevy Car
    58-60"
    49-54
    Chevy Car
    58-60"
    47-54 & 55 1st Series
    Chevy Truck
    60-62"
    Most Early
    Buick,Olds, Pontiac
    58-61"
    28-31
    Ford Car/Pickup
    57 1/2"
    32 & 33-34
    Ford Car/Pickup
    56 1/2"
    35-48
    Ford Car
    57-60"
    35-41
    Ford Pickup
    56-60"
    49-58
    Ford Car
    57-58"
    49-56
    Mercury
    57-58"
    49-51
    Mercury
    61"
    64
    Falcon
    58"
    67
    Cougar
    60"
    55-59
    Chevy Pickup
    62"
    Donor Vehicles Front and Rear
    Year
    Cl***ic Vehicles
    Width Front
    Width Rear
    74-79
    Ford Mustang II/Pinto & Mercury Capri/Bobcat
    55 ½"
    55 ½"
    71-77
    Ford Maverick with 8" axle
    56 ½"
    75-80
    Ford Granada with 8" axle
    57 ½"
    64-66
    Mustang
    57"
    67-71
    Mustang
    59"
    72-73
    Mustang
    60"
    67-69 , & 60"
    Camaro
    60"
    64-67
    Chevelle
    60"
    55-64
    Chevy car
    60"
    65-67
    Nova
    58"
    68-72
    Nova
    60"
    60"
    78 & up
    Monte Carlo, Regal, etc. with 10 bolt axle
    58"
    58"
    68-72
    Chevelle with 10 bolt axle
    61 ½"
    89
    Trans AM (Disc brake)
    62"
    76-80
    Camaro/Firebird
    61 ½"
    60 ½"
    68-83
    Corvette
    58 ½"
    59 ½"
    84-95
    Corvette
    59 ½"
    60 ½"
    Early 70's
    "A" body (Dart/Duster) with V8&3/4 axle
    58"
    "E" Body (Cuda) with V8&3/4 axle
    58"
    Dodge Dart
    59"
    55 ½"
    Plymouth Volare & Dodge Aspen
    61"
    60 ½"
    71
    Blazer (6 lug)
    63 ¾"
    75-78
    Granada 9"
    (43" perch to perch)
    52 ¼"
    75-78
    Maverick 9"
    56 ¼"
    81-87
    Olds Cutl***
    58 ½"
    FRONT SUSPENSION INFORMATION
    Track Width of Popular Donor Car Clips
    Manufacture
    Model
    Years
    Track Front/Rear
    Curb Weight
    Chevrolet
    Nova
    68-74
    59.8-59.6
    3,770
    Buick
    Apollo
    68-74
    59.1-58.8
    3760
    Pontiac
    GTO
    68-74
    59.9-59.6
    3880
    Chevrolet
    Corvette
    68-83
    58.7-59.5
    3655
    84-95
    59.6-60.4
    3890
    Chevrolet
    Camaro (Z28)
    76-80
    61.3-60.5
    3820
    Pontiac
    Firebird (TA)
    76-80
    61.3-60.5
    3900
    Ford
    Mustang II
    74-79
    55.6-55.8
    3305
    Pinto
    74-79
    55.6-55.8
    3305
    Mercury
    Capri
    74-79
    55.6-55.8
    3305
    Bobcat
    74-79
    55.6-55.8
    3305
    Chevrolet
    Monte Carlo
    78-86
    58.5-58.8
    3235
    Buick
    Century
    78-86
    59.0-58.8
    3700
    Pontiac
    Grand Prix
    78-86
    58.9-59.0
    3735
    Plymouth
    Volare
    75-79
    61.0-60.5
    3395
    Dodge
    Aspen
    75-79
    61.0-60.5
    3395
    Dodge
    Dart
    76
    59.2-55.6
    3600
  10. rusty1
    rusty1
    ..if you do the clip rite, no problem; I lap the two frames about 16-18 inches, a lot stronger than a **** joint which isn't suggested with the tophat style frames.
  11. BrerHair
    BrerHair
    Damn gsport, that is awesome!! Can we trust you? I mean, what are your references?
  12. hrm2k
    hrm2k
    Damn shame you have no faith in anyones abilities. There is not a lot of difference between home Z'd frames and frames that are connections as you have described. Our 51 is one of those mixed and matched units. I guarantee that our's will be around long after I am gone. It was done by a certified welder using an oxy/acel torch to preheat all metal to 200 degrees before starting to lay the beads.
  13. mrconcdid
    mrconcdid
    from Florida
    If I may add to this,
    I just did this on my 53
    I stripped an s-10 to the frame, as well as my 53, spent 2 days figuring out it was going to be a real pain to get it perfect. After alot of thinking, the end result was to get a MII and keep the factory frame intact.
    You say you dont have 1800$ for the bolt on, Well i didnt either
    I bought the cross member and uprights from Welder Series by Paul Horton
    (Hamb Member) and bought a complete front end from a Pinto, welded the crossmember in and bolted on the pinto front end, I could have stoped there for a total envestment of around $300 bucks. But i wanted Disc brakes and Power steering so I got a Disc Brake kit for the MII for another $250 which gave me rotors,calipers,bearings and Pads also made it 5 on 4 3/4 bolt pattern to match my Rearend.
    There still were odds and ends Brake lines and Steering shaft to buy and build. But now I have a proven , moderen front end that is safe and best of all the car will hold its value better than a clipped car and my Insurance company dosnt have a problem with it, like some I have heard about ( clipped cars )
    I sorry to say I s****ped my old front end other wise Id tell you to come get it. If you run the numbers you will find rebuilding a old front end is just about as expensive and what I did with all new parts. Keep in mind you will more than likely have to rebuild what ever front end you get.
    I hope this helps
    MrC
  14. SLAMIT
    SLAMIT
    Go with antoher stock front end and rebuild it. You will be happy and it is designed for your car. They work great. unless you are building a canyon carver or a strip warrior why do you need all that BS. You can put disc brakes on your stock front end if you feel the need. The steering is the only thing that I dont care for because of that center dohicky thing but it works........
    And you can stay within the original budget
  15. Troostr
    Troostr
    from Artesia NM
    Anyone know what makes the G body narrower than the camaro? Is it the spindle and A arms or is the frame/cross-memeber set up narrower?
    My problem- I bought a camaro clipped 48 chevy sedan- (from pics- stupid I know) but now trying to work with whats there- I need to narrow the track by 3-4 inches, the pizza cutter rollers I have on it now rub all over and I dont want to run fwd caddy wheels.
    I have read through different threads here- maybe the monte spindles will cut an inch or so- aside from Heidts a arms are there stockers that will slim it up any?
  16. 49ratfink
    49ratfink
    if you are s****ping these 49 - 54 front ends you are tossing 20 dollar bills out the window. part them out and the only thing you might not be able to get rid of is the crossmember itself.
    many moons ago I sold the complete front end from my 49 to a corvette guy who was doing a concourse job and all his A-Arms and stuff were pitted with rust. got 150.00. since then I have parted a 51 and a 53 and got 250 + out of each front end. all useable parts will sell, I even sold the used bearings.
  17. G9mickey
    G9mickey
    Im re-doing the front end on my 48 Biz coupe (the front crossmember was rusted out). I decided to just rebuild the stock one. I bought a crossmember from a guy on the chevybombs site for 70$ (blasted and powder coated). and a rebuild kit will cost about $283 from Kanters (unless anyone knows of a good CHEAPER kit... let me know).
    Otherwise I hear the G-Body is the best way to go on these older Chevy's.
  18. phat rat
    phat rat
  19. rusty1
    rusty1
    I heard S-10 spindles mite help narrow it up some...
  20. rusty1
    rusty1
    you runnin it without any front sheetmetal?
  21. Sam Navarro
    Sam Navarro
    I used the ch***is engineering kit on my 52 chevy and I would do it all over again, it is expensive but there are no headaches and no mistakes to be made. I have heard like others here about the JAG frontends but I would rather get something new with all brand new parts that was designed for my car. Let us know what you decide.
    Good luck
    Sam Navarro
  22. AA/Fuel34fordpu
    AA/Fuel34fordpu
    Well Im gonna just spend the extra cash and do the Ch***is Engineering kit hell its fool proof
  23. gsport
    gsport
    this information was p***ed on to me by another member.. can't remember if it was here or from ChevyTalk
  24. scrubby2009
    scrubby2009
    Got a '79 El Camino frame for my '52 BelAir. Wheelbase is 7 inches shorter so it will get "stretched, but free is a damn good price and I get disc brakes, power steering, open driveshaft and 4-link rear suspension. Somebody grab another roll of wire for the Miller! And for the doubters, I've stretched a frame before... got almost 20k miles on it with no signs of failure or stress, and I don't baby it!
  25. Troostr
    Troostr
    from Artesia NM
    As of right now it looks like the Regal/ Monte Carlo spindle sets are going to get me in just a hair over an inch. We'll see once they ar actually IN the car.
  26. AA/Fuel34fordpu
    AA/Fuel34fordpu
    I called CE today and asked afew questions. They told me the crossmember will lower the car 4". I asked if I could up grade to 2" lower spindles. The guy said I could for $99 but was against it very much. He went on to tell me how bad the steering would be and the tires would rub. Then he went on to tell me that it could rip out a ball joint. Do any of you guys have your chevy lowered atleast 6". If sodo you have any problems? Thanks
