Technical Clutch Bellhousing Clearance
Discussion in 'Traditional Hot Rods' started by 2935ford, Feb 12, 2014.
  1. 2935ford
    2935ford
    I'm working away on my '32 pickup.........
    I have a 265 out of a '55 sedan.
    I have the trans adapter bellhousing with clutch and pp attached to a '35 top loader.
    Here's what I ran into.......
    The clutch ears and high spots are s****ing the trans bellhousing?
    Did a little grinding to make it clear the housing.
    Anyone else with this combo have a similar issue?
  2. brokenspoke
    brokenspoke
    Did you grind the clutch or bell housing?.....Hopefully not the clutch as that messes with the balance of it
  3. 2935ford
    2935ford
    Thanks.
    Yes, we are aware of this. We had to do a little of both. Fortunately, it is a low hp motor and we were careful to do equal to all arms. It wasn't anything major.
    Just didn't know if this was a common problem with this type of conversion.
