Building a 32 ford highboy (kit). The frame has the typical brake pedal bracket welded to the frame to include master cylinder and booster. I now going to use a 4 speed which means clutch. Do I need to cut the bracket off and weld on a clutch/brake bracket or is there a retro fit ?
I use the P&J deuce dual pedal ***embly a lot. Welds on the boxing plate and holds the mc for brakes and clutch. You can order it with or without the hydraulic components.
I have moved on and realized that he bracket (Brake only) needs to be cut off and replaced with a clutch/brake bracket. The problem I am now facing is that the power booster will not clear the center tubular crossmember (Looks like a Pete & Jakes). I will be running four wheel discs so the booster will be needed. HELP need suggestions
