Technical Clutch chatter with new clutch.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Jul 20, 2023.
  1. wheeltramp brian
    wheeltramp brian
    I recently replaced my 50 Merc motor in my 41 Ford with another Merc motor and it runs and drives great and no problems with the motor at all. When I replaced it I figured I would get the flywheel resurfaced and put a new clutch in. The clutch and 10-in pressure plate are new not rebuilt and are from Cn 20230708_124302.jpg 20230708_135551.jpg 20230618_145032.jpg 20230711_110449.jpg G Ford parts. It's got clutch chatter pretty bad. I've been driving it for a week now daily hoping something would get better but it's not. I know these cars didn't have anti-chatter rods but I'm thinking of adding some just to see if it will fix the problem. Previously with the old motor and worn out clutch it had clutch chatter also. Any thoughts?
    winduptoy and Tow Truck Tom like this.
  2. onetrickpony
    onetrickpony
    from Texas
    I'm no flathead expert so I may be totally off, but I would check the inner diameter of the pilot bushing versus the tip of the transmission. That's the only problem I have seen cause chatter when everything else us right.
    dana barlow and winduptoy like this.
  3. wheeltramp brian
    wheeltramp brian
    I installed a new pilot bearing with this new****embly and fitted the bearing to the shaft before I pushed it into the flywheel and it was very tight on the shaft
    winduptoy likes this.
  4. Motor mounts are the biggest cause that I have ever seen, a bad mount will cause chatter big time
  5. alchemy
    alchemy
    Are you sure 41’s didn’t have chatter rods?
  6. wheeltramp brian
    wheeltramp brian
    I replaced all four motor and trans amounts a while back so those are all good. As for the anti-chatter rods some say 41 was the last year and some say 40. I can't see where they would attach anywhere or have seen a drawing of it or picture
  7. alchemy
    alchemy
    A countersunk dimple in the top flange of the frame, directly in line with the bosses on the bellhousing.
  8. wheeltramp brian
    wheeltramp brian
    I had it up on the lift the other day and did look for some mounting holes but didn't see any. I'll have a look again today. The bell housing isn't the stock one but I can Fab some mounts for that end
  9. onetrickpony
    onetrickpony
    from Texas
    Has the trans/bellhousing combo run together before? I have seen certain Ford combos where the pilot shaft didn't reach the bushing but it wasn't on a flathead.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    heres a quote from an old thread, showing the 41 rods
  11. wheeltramp brian
    wheeltramp brian
    Mark thanks for that picture that helps a lot. I was thinking that the rods went from the bellhousing back to the x member. One trick pony this combo has been used since the beginning of hot rodding really and I've done this same combo in 29 Ford where I had to make a anti-chatter rod from the trans bellhousing to the rear mount.
    winduptoy and Moriarity like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I guess 41 was the last year for them. there was an improved trans mount after that supposedly controlled the forward aft movement
  13. BJR
    BJR
    Bad motor mounts and transmission mount will cause chatter.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
  15. wheeltramp brian
    wheeltramp brian
    Thanks I've seen that thread and looked over it again. Other options now, may just see if I can Fab something off the front mounts to the crossmember
  16. Nailhead Jason
    Nailhead Jason
    does it chatter at every clutch engagement? or only in reverse? Long rear dropped shackles can make a slight chatter even worse when backing up, since in reverse it pushes the torque tube forward, pushing the entire trans and engine forward causing some wonky behavior with the clutch linkage, making it chatter more since the rear is able to move forward more with the long shackles flexing way more that the shorter stock ones.
    harpo1313 and winduptoy like this.
  17. wheeltramp brian
    wheeltramp brian
    It's got stock shackles in the rear with a few leaves removed. It Chatter's going forward and in Reverse every time
  18. j ripper
    j ripper
    from napa ca.
    There are so many factors with this it’s difficult to chase down. Clutch itself, shaft alignment, mounts, suspension/shocks and so on. Just a little more RPMs at the friction point will get through it.
  19. seb fontana
    seb fontana
    from ct
  20. 1971BB427
    1971BB427
    from Oregon
    Back 50 years ago if we installed a new setup like this and got clutch chatter, we just pulled up to a big tree or power pole and put the bumper against it, then let the clutch out enough to begin to grab, and revved up the engine. Then back away and drive it.
    If the chatter wasn't gone, we tried it a 2nd time. Usually it was gone the first time, and slightly "burning in the clutch" did no harm except to eliminate the chatter.
    saltflats and winduptoy like this.
  21. wheeltramp brian
    wheeltramp brian
    I kind of tried that the other day as my driveway is super steep I let it slip for a minute and went back and forth revving it up figure something might happen but I don't think it's going to fix it. I'll have to Fab up some rods or something in the next couple days
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I can find no mention of what you used to wash off the new P.P.
  23. wheeltramp brian
    wheeltramp brian
    I use brake clean in a clean rag to clean off the pressure plate and flywheel
  24. jaracer
    jaracer
    After you installed the new clutch pressure plate did you check to see that all three fingers were the same height? After being bit once, it's something I always check.
  25. wheeltramp brian
    wheeltramp brian
    I actually did check the height as I installed a previous one and one of the fingers was flopping around. So now I check them every time I do one
  26. wheeltramp brian
    wheeltramp brian
    So today I stayed after work and put the car on the lift and fabricated some anti-chatter rods from 7/16 bar. These things are pretty heavy duty and though they are not adjustable I made it so it's a very tight fit once everything was tightened up. The clutch chatter is exactly the same... I guess it's time for a good name brand clutch like Fort Wayne. This clutch and pressure plate is new and from CnG Ford parts but who knows where they get them from. I've had this problem a few times in the last couple years with new clutches from the parts stores and ended up buying one from Center force that cured it. Just recently I put a 5-speed in a 64 vet for a customer from American Powertrain and their recommended clutch and pressure plate and it chattered like crazy, put the stock pressure plate that I took out back in and it was perfect. Anyone that knows taking a clutch out of a 64- Corvette is they know it's a pain 20230725_170654.jpg 20230725_170706.jpg 20230725_170719.jpg 20230725_171013.jpg 20230725_171019.jpg 20230725_163913.jpg 20230725_163922.jpg
  27. RMR&C
    RMR&C
    from NW Montana
    Yeah, my experience with aftermarket "new" clutches is not very good. I did put a new ZOOM clutch in my latest build though that is working good. Kind of a***** shoot I guess.
    warbird1 and lumpy 63 like this.
  28. saltflats
    saltflats
    from Missouri
    Guess you took the bolts down evenly on the pressure plate.
  29. wheeltramp brian
    wheeltramp brian
    Basically a Criss-Cross pattern. Same as I've done for years
    saltflats likes this.
  30. vtwhead
    vtwhead
    Might look at Ram clutches down in SC as an alternative. Just installed one in my 31 with the Olds. Working well and I had a big issue with chatter prior.
