Technical clutch fork options?
Discussion in 'The Hokey Ass Message Board' started by LTKMUNN, Nov 4, 2018.
  1. LTKMUNN
    LTKMUNN
    from New Jersey
    64' chevy II needs a good clutch fork. what are some options? Bought some so called "heavy duty" fork from speedway not thinking it could have been Chinese. The rivet popped out of the spring while i was installing the trans..... I was little nervous when I saw a Taiwan sticker on it.... seems like I don't have alot of options of forks for that car when I looking around on websites, unless i missed something?....
    anybody have any ideas?
  2. 302GMC
    302GMC
    from Idaho
    I weld up the worn parts of the factory fork, finish by filing back to unworn appearance.
  3. bobss396
    bobss396
    I have a good selection of used factory forks I pick from.
  4. DDDenny
    Original Chevy II (7 o'clock exit) belhousing or otherwise?
    Novas require very specific style of clutch linkage parts because of the close quarters.
    Lakewood makes a nice generic application fork, (see link below).
    May be too long to clear stock Nova floorpan.
    Do you know about this group?
    https://www.stevesnovasite.com/forums/showthread.php?t=210256
    Older thread but may help.
    Lakewood here:
    https://www.jegs.com/i/Lakewood/620/15500/10002/-1?
    CAWELAID=1710622633&CAGPSPN=pla&CAAGID=15769068431&CATCI=pla-224363292071&catargetid=230006180037475546&cadevice=c&gclid=EAIaIQobChMIvrSY24m83gIVWLXACh0RegToEAQYAyABEgI8XfD_BwE
  5. LTKMUNN
    LTKMUNN
    from New Jersey
    I saw those generic forks but hesitated knowing tight clearance/ geometry issue. I am using a lakewood ****ter shield and block plate with a adjstl. lakewood pivot ball. Ill probably go that route.
  6. jimmy six
    jimmy six
    I'm having a problem understanding the rivet popped out. The fork and the spring both go in the groove on the TO bearing. Did he try to wedge the spring part to the back side of the TO lip?
  7. DDDenny
    All good stuff.
    Is it the Lakewood ****tershield with the Chevy II specific part number?
    Jimmy six is right, its possible to install the t.o. bearing into the fork wrong.
    jimmy six likes this.
