Technical Clutch linkage
Discussion in 'Traditional Hot Rods' started by Thomas Green, Dec 17, 2025.
  1. Thomas Green
    Thomas Green
    When going with a sbc and a later model 4/5 speed in a 1940 Ford, what is everybody using for clutch linkage? Hydraulic only?
  2. 3blapcam
    3blapcam
    Are you not using the stock pedals?
    3blap.
    Mr48chev likes this.
  3. Mr48chev
    I don't have time to research it but would have to believe that there are some simple mechanical setups availble that use the stock pedal and the shaft or part there of.
    SoCal kit, rather spendy for the linkage and bracket for the pivit ball but rather simple. It's also something that if you can visualize you could build your own version with a few hours of fabricaton time. Roadster shop also shows the linkage. Screenshot (2295).png Screenshot (2289).png
  4. Thomas Green
    Thomas Green
    I would like to use the stock pedals
    leon bee likes this.
  5. 3blapcam
    3blapcam
    Should be pretty easy then! Mr48Chev found a pretty clean solution...
    Good luck!
    3blap.
  6. Thomas Green
    Thomas Green
    HemiDeuce likes this.
