1952-59 Ford Clutch linkage
Discussion in 'Off Topic Hot Rods & Customs' started by dragonknucks, Apr 12, 2010.
  1. dragonknucks
    dragonknucks
    So I hooked up the clutch linkage this weekend. It sits directly under the exhaust manifold. I'm running the true dual exhaust manifolds. Heard the 55-57 clutch linkage is curved so it wont get in the way of the exhaust. Is there anyone on here that has that linkage, or that can point me in the right direction? I have looked on ebay and such and cant find one. Also need a radiator. Is it true that the 68 big block mustang radiator drops right in? If so, gotta find one of those guys too. Thanks fellas.
    Rocky
  2. dragonknucks
    dragonknucks
    Any body out there that can help??? Would be greatly appreciated!
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Check this out on ebay,put this number in search: 250635538456 Good Luck!
  4. Retro Jim
    Retro Jim
    Rocky , I might have what you are looking for . I have a complete standard clutch set up from a 57 Ford . I have everything from the 3 speed trans to the steering box & column with the steering wheel . I also have the swing peddles and an couple extra "Z" bars . Just send me a PM and I will hunt up what you need .
    Jim
