Clutch master cylinder
Discussion in 'The Hokey Ass Message Board' started by 55fbomb, Jun 22, 2013.
  1. 55fbomb
    55fbomb
    from PA
    On my 58 f100, brake and clutch master cylinders appear to be the same, i am going to a dual pot power ***ist for the brakes but for the clutch side should i rebuild it or just replace with new? mine is leaking. i have done master cylinders on motorcycles before so a rebuild shouldnt be bad, just wondered if there was any reason i should opt for new instead. thanks.
  2. 2racer
    2racer
    rebuild if it is not pitted from rust inside the bore, otherwise go new
  3. 39 Ford
    39 Ford
    Make sure that only the brake cylinder has a check valve, clutch cylinders do not use one. A Google search will show you what I am talking about.
  4. OLD HEMI
    OLD HEMI
    On the one that I had the clutch master cyl. was 1" and the brakes were 1 1/8", I rebuilt mine with no problems. The clutch cyl. has a spring without the valve at the end
    Lee
  5. bgaro
    bgaro
    rebuild if it looks good, last new one i bought leaked worse than the one i was replacing.
