Technical Clutch Pedal adjustment
Discussion in 'The Hokey Ass Message Board' started by Fitzmaurice, Jul 25, 2023.
  1. Fitzmaurice
    Fitzmaurice
    Hello all ,
    New to the H.A.M.B.
    Building a '31 pickup , having difficulty with clutch pedal on a stock 1931 Model A transmission / clutch pedal****embly.
    I****embled based on the instruction and drawings in Les Andrew's book.
    Clutch pedal goes right to floor , no resistance but does come back on its own.
    I have adjusted the****embly as much as I am able at the adjustment but still going to floor very easily.
    What else should I be looking at , would this be a pressure plate issue or throw out bearing possibly ?
    I know there should be some resistance when applying clutch pedal and there is next to none , however pedal does return on its own quickly.
    Thanks in advance.
  2. X38
    X38
    As usual, pictures please... the crystal ball is currently out of order.
    Is this setup completely stock, or something else?
  3. Fitzmaurice
    Fitzmaurice
    Completely stock , Model A transmission and Clutch Pedal****embly as mentioned above.
  4. Does the clutch actually release when the pedal goes to the floor?
    I suspect a disconnect somewhere....... as in "the knee bone is not connected to the leg bone".
  5. Fitzmaurice
    Fitzmaurice
    Yes, 100% releases and comes back quickly to normal position.
  6. Doublepumper
    Doublepumper
    from WA-OR, USA
    Throw out bearing installed correctly...properly engaged in the yoke...not backwards...?
  7. X38
    X38
    So you did. What about the clutch and related parts. New/old? Where from?
