Technical Clutch pedal question
Discussion in 'The Hokey Ass Message Board' started by 66FordRanchero, Dec 3, 2017.
  1. 66FordRanchero
    66FordRanchero
    Hey guys!
    I had the clutch replaced on the Ranchero about 2 months ago (10/5/2017). The pedal was firm and the clutch engagement was great when I first got it back, but while in reverse you can hear a loud whining noise. It goes away when I put it into 1st gear. About a week ago, the clutch pedal started to not fully return when I shift into neutral. (The pedal comes up about half way) Also, when I put my foot on the clutch while it is in that position, there is a vibration in the pedal and i can hear a loud grinding noise. What could cause this issue?
    Thanks!
    -Hayden
  2. gimpyshotrods
    gimpyshotrods
    When you say that the clutch was replaced, how much of the whole ***embly was replaced? Disc? Pressure plate? Throwout bearing?
    Is this an inline-6? If so, is this a "rebuilt"" clutch, rather than a new one?
  3. 55styleliner
    55styleliner
    Reverse can be noisy while moving because they are often straight cut gears. It sounds to me like your issues are more transmission related and not clutch related.
