1952-59 Ford Clutch pedal
Discussion in 'Off Topic Hot Rods & Customs' started by Avgas, Aug 24, 2017.
  1. Avgas
    Avgas
    Morning, looking at converting the original clutch pedal in my 56 Fairlane to an hydraulic unit. Has any knowledgeable person performed such wizardry on there similar model & if so how? Thanks in advance Wayne
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Way back in the archives here there has been guys that did a SBF and T-5 swap they adapted fox body Mustang units,this may help give you an idea what is involved:
    Avgas likes this.
  3. bobss396
    bobss396
    I used a 3/4" Wilwood master and 7/8" Speedway slave on my '59 also an AFCO stock car hose. Pedal pin is in the stock hole. I made up a plate to mount the brake and clutch master also a plate on the bellhousing to locate the slave. It works nicely.
    Avgas likes this.
  4. Avgas
    Avgas
    Bob, just going thru these 2 pics, a couple of questions! Is there an original mounting point on the firewall for the clutch or did you mount the master there & fabricate the reinforcement for the cylinder? Looks like a nice clean conversion! Cheers Wayne
  5. bobss396
    bobss396
    Both masters are on a common 1/4" steel plate. Aluminum won't work, too much flex. The clutch master is in the stock clutch arm hole, but moved outboard to the other side of the arm. Took a little trial and error.
    Avgas likes this.
  6. Coalshaft
    Coalshaft
    Modern Drive Line is making a kit for a 55/56 ford conversion......I'll let you know how it works when I get it installed .....Hopefully by May
