Clutch safety switch?
Discussion in 'HA/GR' started by REJ, Mar 11, 2010.
  1. REJ
    REJ
    from FLA
    I was told that we may need to install a clutch safety switch to p*** tech at the HAMB drags this year.
    Anybody got any ideas of a simple but effective way of doing this? It would be nice to be able to byp*** the switch if you needed to push start the car.
    I was thinking of installing like a starter ****on that the clutch or linkage would open so the circuit is complete. Does this sound logical?
    Thanks, Robert
  2. iagsxr
    iagsxr
    Mount a momentary push ****on switch like you'd use for a starter switch so that when the pedal is depressed it completes the circuit(to the solenoid).
    Power for the ignition should be totally seperate of the starter circuit anyhow so push starting is not effected.
  3. OBFB HA/GR
    OBFB HA/GR
    Hey Robert , you'll get away with using a brake light switch mounted to your clutch pedal that interupts the power to the starter solenoid exiter wire , when the clutch pedal is depressed it connects only the starter.
  4. Old6rodder
    Old6rodder
    from SoCal
    We prefer a neutral safety (ours is a pair of micros on the shifter), will not allow starter to turn in any gear, clutch or no clutch.
    Ignition should always be seperate from starter as already mentioned.
  5. Junior Stock
    Junior Stock
    Is this what you saw? Got it off their site.
    Neutral Safety Switch
    All cars must be equiped with a functioning neutral safety switch that prevents the car from being started in a forward or reverse gear.
    The last rule book I saw was in 2004 and it only stated automatics had to have a neutral saftey switch. Hopefully Carl can clearify this.
    Hate to come up there and not be able to race.
    Tim
  6. Old6rodder
    Old6rodder
    from SoCal
    To the best of my knowledge, officially, a neutral safety switch is still required only for slush pumps, and sticks are recommended to have at least a clutch activated switch.
    That said, the techs out here really like to see the neutral switch anyway, and that's our own team's preference as well.
    I still need to get a '10 book.
  7. REJ
    REJ
    from FLA
    I did not get this information off of their site. I was told when I tech'd last year that they would prefer that the stick cars had a clutch safety switch.
    I figured I would install one to be on the safe side before I pulled 1500 miles and had to rig one in the parking lot.
    I think I will install a push ****on type switch.
    Thanks for all the replies, Robert
