Technical Clutch Setup - 4 speed conversion on 57 Chevy
Discussion in 'The Hokey Ass Message Board' started by TimCT, Jul 15, 2019.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    Further proof you can't fix stupid !!
  2. DDDenny
    Gives a whole new meaning to the term "limited slip"!
    Hombre and chevy57dude like this.
  3. 56sedandelivery
    56sedandelivery
    Probably a DANA Arma-Steel Positraction; that's what they were stock. I am Butch/56sedandelivery.
  4. 56sedandelivery
    56sedandelivery
    That would be "NO Slip". I am Butch/56sedandelivery.
    Hombre likes this.
  5. TimCT
    TimCT
    @squirrel - you're correct, I'm using the bearing that came in the clutch kit, which is a bent finger/diaphragm, not the borg & beck style. I measured it last night, wrote it down, and left the measurement on the workbench. So, perfect. But if I remember right, one of the uses of the adjustable pivot ball is to compensate for multiple TO bearing heights. At any rate, I'll get the measurement off the bench tonight.
    I pulled it all apart (it came apart smoothly, no prying) and removed the pressure plate. Checked out the pilot bushing and it looked fine, no mushrooming or any other damage to speak of. Line up tool slid in nice, and the test fit of the input shaft went in smooth as well, so at least I know I didn't wreck anything.
    I thought I had this figured, because it looked to my eye like the TO bearing wasn't centered in the opening in the bellhousing.
    Looks off, right? I immediately thought I needed a longer fork, but then took a second (third, fourth, fifth) look and I think it was just the angle. I squared up the bearing face with the bell and took several hundred measurements around the bearing, and they were all about 0.010" within each other, which I think counts for centered.
    Next step is to get my dial indicator out and see how far off the bellhousing is. Is it all that common for these to be made so far off that they require the offset dowels?
    Thanks for the help guys, I really appreciate the advice. Sometimes a project has you stepping out onto the ledge...
  6. squirrel
    the TO bearing is upside down in that picture...I hope you installed it properly when you had it all together?
  7. TimCT
    TimCT
    Well, isn't this embar***ing...
    dwollam, Hombre and squirrel like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. Kinda dry in the pilot bearing. You need a bit of ch***is lube on it.
    Hombre and Torkwrench like this.
  10. TimCT
    TimCT
    It did initially, but I wiped it clean to check it out.
  11. squirrel
    sometimes being embarr***ed fixes a problem :)
    Hombre, Old-Soul, Torkwrench and 2 others like this.
  12. TimCT
    TimCT
    Fingers crossed that was my issue. Loose nut behind the wheel...
    lewk, Hombre, Old-Soul and 1 other person like this.
  13. thecj3man
    thecj3man
    from TN
    I put a Lakewood in my 55 last winter and it was about 0.007 out. I think the instructions that came with my TKO wanted it to be within 0.010, but I cant really recall now. I do know that it was within the specs so I didn't install offset dowels.
  14. the problem with offset dowels is then the bolt holes attaching it to the block are not lined up. I waller the alighnment dowel holes in the ****tershield until its centered then weld a small patch with the correct size hole to the outside bellhousing. Still sometimes have block to bell bolt hole misalignment a bit of filing with a round file takes care of that so it fits. my block plate is 3/8 thick. so I drilled a couple of holes thru the bellhousing flange and partially into the block plate. welded a fixed nut to the bell and installed a bolt that had the end beveled. then the 4 holes at the bottom are enlarged to where they line up and a tight fitting bolt installed to hold the block plate and bell together.
  15. DDDenny
    57 HEAP likes this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    If this is the case ,while I feel your embarr***ment ,I can't help but laugh !!
    While your checking , is the fork all the way on the pivot ball ??
  17. 57 HEAP
    57 HEAP
    Not that big a deal, a very little amount of grease can't hurt, but the bearing is oil impregnated.
    I never had a problem with bolts not lining up with offset dowels, won't say it can't happen, just has been a problem for me. That said, check this out: https://static.speedwaymotors.com/pdf/42515100.pdf
  18. TimCT
    TimCT
    I laughed too. If I didn't, I'd cry.
    The pivot ball is indeed all the way into the fork, I checked that a handful of times, you know, trying to eliminate the obvious, dumb mistakes...
    Hombre and chopndrop like this.
  19. squirrel
    at least you understand the importance of keeping your sense of humor around
    Hombre and 427 sleeper like this.
  20. I once installed the clutch disk facing the wrong direction. The springs in the disk rubbed the flywheel bolts. Nothing to do but pull it apart and turn the disk the proper direction.
  21. sdluck
    sdluck
  22. chevy57dude
    chevy57dude
    Took a set of .014 offset dowels to get mine right. IMG_20190715_223150721.jpg
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I like that you used only 3 9 then 6 12 o'clock position to take measurements. I never understood measure all around. :confused:
    chevy57dude likes this.
  24. TimCT
    TimCT
    At almost 40, I've gotten really good at making myself look stupid. It would sorta be weird if I didn't.
  25. Yes indeed the older I get the dumber I am. Why couldn't all of lifes great problems happen when I was a teen and knew everything.
  26. TimCT
    TimCT
    We're finally smart enough to realize how dumb we are!
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yep , the older you get , the dumber you get , just imagine how you feel at 71 .!!
  28. TimCT
    TimCT
    Good news. I turned the TO bearing around the right way (thanks @squirrel ) and it all slid together with a little wiggling. No more binding on the clutch fork.
    I'm confident enough now to drop the ***embly back in the car to get the crossmember set up and start to put the linkage together, which I'm sure I'll need help with. Thanks again guys!
  29. tb33anda3rd
    tb33anda3rd
    put the ****** in gear and while someone tries to turn the out put shaft, pry back on the fork. at some point the clutch will release and the out put shaft will turn.
  30. TimCT
    TimCT
    To make sure the clutch does indeed release?
