Clutch Turbo Info
Discussion in 'The Hokey Ass Message Board' started by Humble Jon, Jan 24, 2013.
  1. Humble Jon
    Humble Jon
    I am finishing up an old B&M Clutch Turbo unit. My question to any one is, what release bearing did they use? The sleeve is 1.62 OD.
  2. Jalopy Joker
    Jalopy Joker
  3. GassersGarage
    GassersGarage
    Contact Vic Young or Kiwi Kev, here on the HAMB. Vic runs one in his Henry J.
  4. I had clutchflites years ago. I don't remember exactly what bearing was on it but start looking at 4 speed stuff. The length will be real important. The pump fingers need to engage around 3/4 of an inch so they don't disengage when you depress the pressure plate. Depending on what style of clutch you're running there will be a substantial difference in the length of the throwout bearing.
  5. Humble Jon
    Humble Jon
    Thanks. I will check into the special lengths as I can see,thats gotta work. As soon as the Bellhousing is finished at the powder coating I'll work on the bearing.
