Hot Rods Clutch woes
Discussion in 'The Hokey Ass Message Board' started by jefscoupe, Sep 25, 2025.
  1. The actual cross pin width plus a 1/16.
    That's the only "stop point" I see inside the center section. [/QUOTE]
    Correct
    Are the axles supposed to touch the cross pin? [/QUOTE]
    You don't want contact.
    I'd think a little "breathing room" would be needed. A 16th at least. [/QUOTE]
    When dealing with Dutchman axles the 1/16" is figured into his pattern for measure
    I picked up the finished housing yesterday. [/QUOTE]
    I guess that explains this photo, [​IMG]
    jefscoupe and winduptoy like this.
  2. jefscoupe
    jefscoupe
    Waiting on my last pieces to put it back together.
    I decided to (for now) use the axles as they are. They pulled OK on my last test drive.
    Axles are relatively easy to change out. I don't have to remove the whole axle housing and all.
    I need to get some drive time in and check other systems...like brakes.
    I will to a stationary test with it up on stands to see (hear) if the clunking has gone away.
    Pist-n-Broke likes this.
  3. Thanks for the update. Hopefully you'll find the noise is actually just the exhaust touching the frame or a suspension link (heim end) making a bit of racket ... something along those lines.
    jefscoupe likes this.
  4. Happydaze
    Happydaze
    If you've not already got one, treat yourself to a mechanics stethescope. Best 10 dollars or so you'll ever spend! Sure you can do it with a dowel, screwdriver or similar but the sensitivity of the correct tool is amazing. You'll go around testing everything! They're also rather light and long so I feel they're much safer too, especially for the likes of me with girly hair!
    Chris
  5. jefscoupe
    jefscoupe
    I HAVE one of those. I bought it several years ago...now if it can find it...
    I STILL have the clunking sound. From inside the car, it sounds like it's coming from the rear.
    From outside I can't really tell. It's awful.
    Car on stands sitting on the axle, so full weight on the axle. It sounds like something in the rear end.
    I rechecked the pinion angle. I adjusted it to match the angle of the trans hoping that was the problem. Nope.
    Neutral, clutch out, nothing. Third gear at idle it clunkity plunkity like the gears have a rock floating around. It's driving me nuts. Leaving the car running, in gear, I can feel it in the shifter. I leave it running and go out back and put my hands on everything and I can't feel anything. Exhaust is not hitting anything or rattling. After a minute, it gets so bad I run around and shut it off.
  6. 60 Special
    60 Special
    from Omaha Ne.
    Could it be something in the ******? I have read your whole thread, but can't remember what you said about ******. Maybe remove drive shaft and check for same noise you are now hearing? 60 Special
  7. This is just to Bazarr! Might be time to call in another set of ears to help with location. Maybe trailer it over to a shop that does Trans and Diff work mechanic's there take a listen. You're convinced everything is Right yet something isn't. Might be time to trailer it to a Trans - Diff shop and have them take a listen. Tearing it apart again is just more time and $$$ spent for what? Getting Old ****s
  8. jefscoupe
    jefscoupe
    I did test that before I put the driveshaft back in.
    Clutch out, engine running trans in 1,2 and 3rd gear.
    Quiet, no clanking.
  9. jefscoupe
    jefscoupe
    I’m pretty much “there” now (trailering it somewhere).
    Getting old does ****, but it beats the alternative.
    I’ve got just under 2 weeks to the show.
    Tim_with_a_T likes this.
  10. I feel your pain buddy.
    winduptoy and jefscoupe like this.
  11. Tim_with_a_T
    Tim_with_a_T
    Keep us posted
  12. Kevin Ardinger
    Kevin Ardinger
    Geeze! So, no load on it, wheels in the air, a rhythmic clunking from the rear? With the rotation of the rear wheels? Same on the road? Would you say it is at wheel speed or faster? If you were to kick it into neutral, still there?
    jefscoupe and 427 sleeper like this.
  13. RICH B
    RICH B
    Have you checked the gear lube for metal after or the magnet on the drain plug if it has one after the round of clunking?
    I'm sure you tried it; but if you turn the driveshaft by hand can you feel or sense anything?
  14. Kevin Ardinger
    Kevin Ardinger
    I don’t remember from all the post. Drum brakes in the rear? If so, it is very possible a brake shoe is catching as the drum turns. That I have experienced before and it can sound as you describe. Pretty loud!
  15. jefscoupe
    jefscoupe
    Drum brakes, adjusted fairly loose. But that's another avenue for me to check.
    No drain plug. I pumped out the oil the last time I took it out, just a little "dust" in the bottom after it settled for a few days.
    I noticed a marked improvement in the ease of turning the rear yoke by hand after having the housing fixed. (I DID clean it out with engine cleaner, water hose sprayer followed by brake clean and rags ran through the axle tubes and the rest of the housing before re***embly)
    I can hear no clunking or s****ing turning it by hand in either direction. Drive shaft connected or not.
    I heard it initially on my first drive (the video) and I didn't hear anything until I got enough speed to get 3rd gear, then it started.
    It generally starts once it gets some speed. I don't really hear anything in first, until I rev it up more.
    I called places I know of around here and everyone is busy. Mid December before I can get it in somewhere. The show (Rodders Reunion) is a week from this Thursday. I've decided to leave it as is until after that. It'll move itself from the trailer to the building, I just can't go much more than a crawl.
    I wish I could post a couple videos. For some reason the HAMB won't take a .MOV or a MP4.
    I'll try a new post and see if it'll take it. I'll call it "Rear Axle Woes". If you don't see it, it didn't work either.
  16. Tim_with_a_T
    Tim_with_a_T
    You can upload your video to YouTube, then embed the video here, by using this ****on (copy from YouTube, paste link here):
  17. In your posted photo of the Dog Bone in place and both axles in place the Axle to the right was quite short of the measurement marker. What did you do to correct that? If nothing, I would call the ph# on the dog bone and talk to someone there and get firsthand info as how critical the gap or lack of is. I'd also let them know who's diff parts you have installed. You may get information none of us have covered.
    427 sleeper and jefscoupe like this.
  18. jefscoupe
    jefscoupe
    Thanks, I'll try that.
    Did I post the first drive video? I thought I did but now I can't find it.'
    See if either of these work. The share one is the axle noise. It wouldn't let me embed it.
    https://youtube.com/shorts/ttnQYKLvL3c?feature=share
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    they both work. Shorts (videos less than 1 min) are always a red clickable link while longer videos show up as a picture in the post. Also you don't need to use the media link to post them, you can simply paste them into the body of your post
  20. jefscoupe
    jefscoupe
    OK, thanks.
    winduptoy and Moriarity like this.
  21. 59sedandelivery
    59sedandelivery
    NOW THATS what it ALL about right there!!!! Congrats....
  22. jefscoupe
    jefscoupe
    It was pretty cool until I heard a clanking and thunking. I immediately pulled into the neighbors driveway and turned around.
    Still haven't determined the cause.
    I decided to work on a lawnmower and see if I could fix THAT...
    So far go good on the lawnmower. LOL
  23. jefscoupe
    jefscoupe
    I'm back...finally. I got so disheartened I just quit for a while. The Holidays and all were coming up so I walked a way from it for a while. A month ago I got in touch with a local diff and driveline spe******t and scheduled with him to take the whole axle to his shop on a Saturday. That Friday is snowed and iced so bad I didn't want to risk it. The next weekend he was out of town. I finally got with him the following Saturday and it took him another week to get it all checked out and put back together. I picked it up today.
    There was a clearance issue he had to grind some relief for the ring gear. And he said both axles were short. The short axle needed another .200" and the long side needed .450".
    So...New axles ordered along with bearings. Now I wait another week or so for those to come in. And I STILL don't know if that was my noise problem. Whee! Working on old cars is so much fun...
    Deutscher, Tim_with_a_T, GuyW and 3 others like this.
  24. Happydaze
    Happydaze
    Having to get some interference relief for the ring gear sounds promising in the hunt for the kind of noise you've been chasing.
    Chris
  25. jefscoupe
    jefscoupe
    I'm hopeful, but not holding my breath.
    I'll just have to wait and see. I got the bearings today, the axles are not due in until next week.
    I've about decided that if the noise is still there, I'm just going to drive it until it shows...SOMETHING, or breaks in half.
  26. jefscoupe
    jefscoupe
    Hey! My axles came in early. Today! Tomorrow is shop time!
    Deutscher, ZerroHalfcup, GuyW and 4 others like this.
  27. jefscoupe
    jefscoupe
    Well...if it wasn't for bad luck...
    I went out last Saturday to prep my new(est) axles and I started measuring to cut them to the "correct" length. I measured up the long axle first, mainly because that happened to be the one I picked up first, and get it measured and marked the new one with the additional length added per the diff and driveline guy's recommendations. I pick up the old, .200" too-short, short axle and measure, adding the recommended length. I pick up the new short axle and it's 3 inches too short already.
    WHAAAAA?
    One more new axle on the way. Jeeze Louise!
    The old new long axle that was too short could have been cut to use as the short axle but when I measured it, it would only have maybe an inch of spline left. Maybe that was enough, maybe not. The new new long axle I could cut to the short length and still have 4 inches of spline left. So I ordered another one of those. Confusing? Absolutely.
    Driving me crazy? Yeah, I'm there and have arrived with no luggage.
  28. Happydaze
    Happydaze
  29. jefscoupe
    jefscoupe
    All back together! Still makes the clunking sound.
    :mad::(
    If I ever figure it out. I'll let you all know...
    Deutscher likes this.
  30. Doublepumper
    Doublepumper
    from OR-WA, USA
    You mentioned they're new, but at this point it's time to pull the u-joints and check them over. Possibly one of the rollers got tipped over and lodged into the grease slot at the end the yolk. That could cause the remaining bearings to run out of alignment, causing noise when they bind up, then try to straighten out.
