Projects Cmichael AV8 coupe build
Discussion in 'Traditional Hot Rods' started by cmichael, Sep 26, 2015.
  1. cmichael
    cmichael
  2. cmichael
    cmichael
    Got the pedal bracket built just have to drill the hole in it for the MC. Took the body off to ****on up the ch***is and tear it down and paint it.
    ImageUploadedByH.A.M.B.1444520858.487745.jpg ImageUploadedByH.A.M.B.1444520875.289469.jpg ImageUploadedByH.A.M.B.1444520887.107841.jpg ImageUploadedByH.A.M.B.1444520907.408828.jpg
  3. Really like this build, good job, I'm watching!
  4. cmichael
    cmichael
    Made a drag like from a f-1 tie rod and drag link. So steering is done except for deciding on a column drop. Then I blew it apart filled some hole in the ch***is welded everything up and put a coat of ch***is black on it. Start re***embly tomorrow! ImageUploadedByH.A.M.B.1444599226.840945.jpg ImageUploadedByH.A.M.B.1444599238.243184.jpg ImageUploadedByH.A.M.B.1444599254.361857.jpg
    I think this one will fall in the "good from far but far from good" category!
  5. cmichael
    cmichael
  6. cmichael
    cmichael
    Painted the engine and Trans tonight since I'm waiting on hub bearing and tie rod ends to finish the Frontend.
    ImageUploadedByH.A.M.B.1444696280.729120.jpg ImageUploadedByH.A.M.B.1444696319.329336.jpg
    Denns1989, waxhead and AHotRod like this.
  7. AHotRod
    AHotRod
    Looks like your doing a fine job...well done
  8. cmichael
    cmichael
    Put the engine and Trans back on the ch***is last night.
    lodaddyo and AHotRod like this.
  9. cmichael
    cmichael
    Put the dizzy and new plugs and wires on the motor. Also put an aluminum intake on that I had on the wall but it's not going to work it's shorter under the fuel pump. So I guess I'll run the stock one until I get a high rise pm-7. I'm not going to run the low one I have because I want to run a mechanical fan off the generator and it hits the front carb. ImageUploadedByH.A.M.B.1444868251.057892.jpg ImageUploadedByH.A.M.B.1444868261.425160.jpg
    I made up a clutch linkage also. I think it's going to work out pretty well. At least I hope!
    ImageUploadedByH.A.M.B.1444868300.297030.jpg ImageUploadedByH.A.M.B.1444868311.133362.jpg ImageUploadedByH.A.M.B.1444868321.750541.jpg
    I also installed some little aluminum brake line brackets I made up.
    Thanks for following along! And all the nice comments!
    Hotrodmyk, waxhead and AHotRod like this.
  10. Pete
    Pete
    Looking good Cam, keep it up, before you know it youll be driving it.
  11. cmichael
    cmichael
    Thanks Pete. You said you have two a's going in your shop build I can only find one build thread???? Am I missing something? How did yours do at TROG?
  12. Pete
    Pete
    The other build is the Flaven and Flaven model A build, it's been a little slow but plan to get back on it soon.
    Trog went great, car went great no problems.... Lost some races and won some....
  13. cmichael
    cmichael
    Painting the rearend today.
    And I brought my helper Lila to the shop today.
    hdalex and AHotRod like this.
  14. Rem
    Rem
    Great build. Are you not using the F1 crossmember now that you've fabbed a pedal bracket? Or is that still to come?
  15. cmichael
    cmichael
    Thanks! No I'm not using it anymore. I found two different ones but the owner kept giving me the run around so I got impatient and gabbed Trans mounts and pedal mount. If they finally come thru I may swap it out or just use it on the next one.
  16. cmichael
    cmichael
  17. U-235
    U-235
    Motor mount question......how did you know where to place them without the body on the frame...?
  18. cmichael
    cmichael
    I didn't really I just had them tacked in until I got the body. I had to move them.
  19. BenLeBlanc
    BenLeBlanc
    VERY COOL!
    I am basically doing the same thing as your in my build in my signature; but you are flying on through time wise! Will be cool to see.
    I don't have my body all ***embled so I cannot see where everything is supposed to be. So on your steering and pedal setup- You running an A box, or what? That looks to have a round shaft for the pitman arm and I got a square one in my box. Also, how far was the move rearward?
    BTW, are you boxing or what are the plans? I have been making braces and such, but am interested to see what you come up with. LOVE the trans mount idea- tossing up if I should go nice and easy like you, or ingenious like what pete did by mounting it off of e- brake shaft.
  20. louisb
    louisb
    Good looking build. Love the roof detail, hell I may copy it on my coupe.
    --louis
  21. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Signed on for the ride, if your ever up this way stop in.
    just picked up another one for a banger build.
  22. lodaddyo
    lodaddyo
    Looking good! I cant wait to get started on mine
  23. cmichael
    cmichael
    Thanks! I'm running an f-1 box i think I moved it back about 1.5 inches. I'm not planning on boxing right now. Bone stock motor. Plans are to get it going and build another ch***is with a built full race flathead next.
  24. cmichael
    cmichael
    Yea
    Thanks! I would love to where are you located?
  25. cmichael
    cmichael
    Thanks for the kind words!
  26. barrnone50
    barrnone50
    from texas
    Looking real fine on the your Coupe ! The roof detail looks like one on saw back in the 60s. Can't remember maybe a 34 Plymouth Coupe. It had Aircraft style rivets. Really like the look. Great Job on the trans mounts making it work!! Keep your progress coming really like what you are doing!
  27. cmichael
    cmichael
    So I haven't made much progress lately! I'm a Propmaker by trade in the film industry and things are crazy at work right now. But my buddy to my wheels to a place that will sandblast and powder coat them for $25 each! Sweet deal I thought and they turned out great! Hopefully this weekend I'll get some things done! I need parking brake linkage ideas so feel free to share. I have a modal a handle I want to use.
    Picture of the wheels.
    Tuck and AHotRod like this.
  28. Pete
    Pete
    Yea man, they look great....
  29. lodaddyo
    lodaddyo
    They look great and thats a deal! I just paid $275 to get these sandblasted and powdercoated.
    Mikel50 likes this.
  30. swifty straights
    swifty straights
    looks great! i can't wait to see more pics! and i also love the roof! you do great work
