Hot Rods Cody Walls Builds 32 Ford 3 window coupe “The Ardun Killer “ .
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Aug 21, 2019.
  1. LAROKE
    LAROKE
    Nice solution to the radiator hose timing gear cover interference problem inherent with the stovebolt and Jimmy six engines, Cody.
    jim snow, Cody Walls and loudbang like this.
  2. Cody Walls
    Cody Walls
    I originally saw it done on the Bill Kelly coupe . And saw that br***works offered it . So it should make things a lot easier
  3. flatmotor40
    flatmotor40
    from georgia
    Hot Rod Works did my 40 rear end some 10-12 years ago Great people
    kidcampbell71 and loudbang like this.
  4. Just checking in on the progress. Love the rear wishbone idea.
    loudbang and Runnin shine like this.
  5. Nice progress
  6. -Brent-
    -Brent-
    This is car is really neat. I love all the little details.
  7. Cody Walls
    Cody Walls
    Marshall making progress on my Wayne motor .
    Outback, alfin32, Cosmo49 and 23 others like this.
  8. pbr40, NoSurf, Stogy and 6 others like this.
  9. Blues4U
    Blues4U
    from So Cal
    Stogy, chryslerfan55 and loudbang like this.
  10. Cody Walls
    Cody Walls
    Thanks guys
    Stogy, Blues4U and loudbang like this.
  11. vtwhead
    vtwhead
    Cody, I luv my Olds engines but that inliner is a 10+ right there. Your setting the pole pretty high man, great project:)
  12. Tim
    Tim
    from KCMO
    Man that radius rod trick is fantastic! How have I never seen let alone thought of that. Genius
  13. Man, I love this one![​IMG]
    Outback, rob-redm, Cosmo49 and 7 others like this.
  14. Beautiful engine set Cody. I see a magazine cover in your future!
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
  15. Don't know which I'm more envious of- the Offy in the corner, or the Riley carbs!!!
    loudbang and Cody Walls like this.
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Very cl***y.
    Trad thru-n-thru.
  17. redzula
    redzula
    Oh man that engine sure is pretty. Love the manifolds, and the Riley's, and the fins, and the channel job, and the trailing arms, and the front bones....etc etc etc.
    Sent from my rotary phone using The H.A.M.B. mobile app
  18. Cody Walls
    Cody Walls
  19. waxhead
    waxhead
    from West Oz
    Outstanding work as per usual.
    Cody Walls, loudbang and Stogy like this.
  20. Stogy
    Stogy
    Many thanks @Cody Walls for sharing this journey with us...truly a joy to witness...every step of the way...
  21. Cody Walls
    Cody Walls
    Marshall finished up my Wayne motor this week and broke it in , next step is to get this thing in the coupe so I can cont to mock everything else up .
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    What size side draft carbs will you be using?
  23. Cody Walls
    Cody Walls
    I would love to run the Riley’s 2” but there almost impossible to find and from what I here there not streetable,
    So I’m going to run 3 early Weber 40 Dcoe . If I can find Dco3 even better
  24. vtwhead
    vtwhead
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Three Weber side draughts look great on an inline six.
  26. Speedy Canuck
    Speedy Canuck
  27. Cosmo49
    Cosmo49
    A good friend machined the bottom of the cover flat. Seen here p***ing the ‘slip of paper test’ with flying colors.
    Outback, Tman, David Gersic and 10 others like this.
  28. Cody Walls
    Cody Walls
    Y
    Nice looking valve cover you got there . I’m surprised that your cover needed to be machined flat , as being that is a fairly new aftermarket Wayne valve made by Patrick’s for a standard 216/early 235 head and the casting on them we’re pretty good . I’m glad you posted a photo of this because a lot of people don’t know the difference between a aftermarket one for a stock head and a real Wayne valve cover
    The way you can tell the difference is the original Wayne valve covers had two breathers , the cover it self is narrower and the bolt holes are closer inline with the Wayne name .
  29. Cody Walls
    Cody Walls
    Yes they do
  30. Cody Walls
    Cody Walls
