COE COE Brake systems??
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Mar 28, 2013.
  1. wetskier2000
    wetskier2000
    from NH
    OK, I think I finally have my steering issues solved.. On to the brakes...
    I need a power setup to drive Dodge 4 wheel disks with very limited "underhood" real estate. Ideas so far are: 1) Custom right angled set up where the pedal pushes a rod then a bellcrank of sorts. MC and booster are mounted sideways. 2) Purchased under floor setup.
    What have you guys done?
  2. buggy5872
    buggy5872
    Mine is inside the cab behind the dash. It has a remote resivor on the outside of the fire wall. All mine came from the 2003 GMC w4500 I used for the ch***is. You need a lot of room behind the dash though. I made my firewall from scratch to fit the setup.
  3. wetskier2000
    wetskier2000
    from NH
    I see from your pics that you turned the entire booster and MC around and push towards the rear with the pedal. That's cool, was it oriented that way in the donor? Not sure if I have that much real estate under the dash...
  4. 27 tallt
    27 tallt
    :DI used a complete brake booster and master with linkage and pedal from a Dodge van ('80's). Almost a bolt in except I had to trim the inner shroud (that touched the booster) of the grill shell. Looking at it one would never know that it was trimmed. The whole thing was on the other side of the firewall.
  5. wetskier2000
    wetskier2000
    from NH
    Got a pic of the 80s Dodge van setup, by chance??
    thanks
  6. buggy5872
    buggy5872
    It was already inverted in the GMC when I started.
  7. wetskier2000
    wetskier2000
    from NH
    Thanks for the GMC, motorhome brake set up pic. Was that whole right angle deal part of the motorhome or did you need to fab that? It really fits in there nice.
    What year was the motorhome?
    thanks
  8. The one I used was from 1984. The hydro boost is attractive as it is compact and supplies good brake boost. I had to modify the mount to work in my application.
  9. wetskier2000
    wetskier2000
    from NH
    Did the hydro boost have a belt driven pump? Seperate from the power steering or the same unit?
    thanks,
  10. Both use the same power steering pump.
  11. wetskier2000
    wetskier2000
    from NH
    Hey Buggy, could you take a measurement from the firewall to the closest point near your knee for your GMC brake setup. Also, some idea of how far up under the dash or not the thing is would be handy. This is a vacuum booster, right?
    thanks,
    Rick
  12. rustynuts 1939 coe
    rustynuts 1939 coe
    I used a dodge van 90 degree mount with i ton dually master cylinder and 9 inch dual diaphram booster check pics of my coe it works well
  13. wetskier2000
    wetskier2000
    from NH
    Thanks RustyNuts! Any idea what specific year the Dodge van was?
  14. buggy5872
    buggy5872
    I will try to get some measurements for you. It is a vacuum booster. Probably wont be until later this week. The truck is not at my house.
  15. rustynuts 1939 coe
    rustynuts 1939 coe
    1969/1970 dodge van pretty sure
  16. buggy5872
    buggy5872
    Rick, I was looking at your pics and I see you have a tilt cab. Being that my set up is off a tilt cab originally....it might be a good choice for you if you can make it fit.....if you get all the lines it has rubber lines just outside the firewall for the tilt.
  17. wetskier2000
    wetskier2000
    from NH
    Buggy, I found your setup in a GMC commercial cabover box truck. It really came back too far towards my knees to work, but I definitely appreciate the input. In the meantime, I have located a 90 degree underhood unit in a cube van. (It was a storage unit at a local junkyard). Pulled it all today and will put the corvette booster and MC in place of the cube van's hydroboost system.
    Stay tuned...
  18. buggy5872
    buggy5872
    Glad you found something... I had a rough weekend and did not get a chance to look at it for you.
