COE Group
Discussion in 'The Antiquated' started by xtremek, Jan 24, 2024.
  1. xtremek
    xtremek
    Hey Folks,
    I was told there was a COE group on here. How do I find them? Sorry to be a pain, but I didn't see them when I did a search under COE or cab over.
    Thanks,
    Kirk
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  3. xtremek
    xtremek
    Thank you for your help....so far. Sorry to be a pain. It says I don't have privileages to post there. How do I get the privileages? I'm about to start building my '52 Chevy COE.
  4. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  5. pprather
    pprather
    Bill's Auto Works likes this.
  6. wraymen
    wraymen
    It appears that the COE forum is not very active.
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  8. Cabover people...
    Obv. it is a White. My question is "Can you identify the year?" (Because I don't know) 20240306_151413.jpg 20240306_151451.jpg 20240306_151457.jpg 20240306_151509.jpg 20240306_151555.jpg 20240306_151559.jpg 20240306_151446.jpg
  9. 41 GMC K-18
    41 GMC K-18
    Hey @23 Skidoo and @xtremek
    One of our fellow hamber's @Jamister1 is the go to guy, that can tell you all about those cool
    " WHITE TURTLE COE'S "
    I included his user name here, so possibly he will see this and respond. I am sure he can identify the year of that rig for you.
    Thanks from Dennis.
    23 Skidoo and down-the-road like this.
  10. Okie Pete
    Okie Pete
    Grab the steel lawn chairs also
  11. I would be lucky to get the cabover. Hoarders.
    & The neighbor with the fastest / easiest access doesn't want me to cut the single Cedar that is blocking a mostly clear extraction.
    I'm thinking...
    1. Drop / disengage the drive shaft.
    2. Remove the wheels & get new sneakers on them (cut off tires, laser or acid dip clean the wheels, replace wheel studs if needed).
    3.Try to soak the hubs & free up any rust; need rolling wheels.
    4. Cut Cedar out of the driver's side rear leaf / frame area.
    5. Cut Cedar out from neighbor's access (I will offer a hundo & start from there).
    6. If a roller, haul to my place around 25 miles W of this location.
    Also needs side & front gl***.
    ...I have ideas that include stretching it into a 4 door, keeping the tilt cab functionality, adding A/C (this is Texas, after all), making it a 6×6 / adding a transfer case & slipping a ***mins 12v under that tilt w/ the back 2 seats having a shared center arm rest that goes over the engine.
    See, also: disc brakes all around, power steering, power windows, full seat belts.
    Uncertain on front bench or buckets.
    Big honkin' tach, full instrument cluster, psi boost readout, oil temp / pressure, RPM, trans & water temp, etc.
    elgringo71 and Okie Pete like this.
  12. RMR&C
    RMR&C
    from NW Montana
    Biggest challenge to making it roll will likely be the brakes rusted solid. Been down that road...
    Best of luck, looks like a cool project!
    23 Skidoo likes this.
  13. Nothing 40 cans of P.B. Blaster can't overcome.
    Spray, walk away for a few days, lather... rinse... repeat 2 or 3×.
