Customs COE panel metal work
Discussion in 'The Hokey Ass Message Board' started by the metalsurgeon, Sep 16, 2014.
  1. the metalsurgeon
    the metalsurgeon
    from Denver
    Modifying one panel to match the fuller panel.So making the left side look like the side in the first picture.
    need help, skilled metal workers,$25ph and upwards depending on skill level reply with resume to valerie@themetalsurgeon.com
  2. the metalsurgeon
    the metalsurgeon
    from Denver
    countinued...
  3. the metalsurgeon
    the metalsurgeon
    from Denver
    metal finishing stage
  4. the metalsurgeon
    the metalsurgeon
    from Denver
    metal finishing continued
  5. chopolds
    chopolds
    from howell, nj
  6. MP&C
    MP&C
    Looks good!
  7. mcmopar
    mcmopar
    from Strum, wi
    Looks like good work, how many hours into it? Are you looking for people to work for you at that hourly rate, or is that what you paid to get it done?
  8. the metalsurgeon
    the metalsurgeon
    from Denver
    the panel as you see to date has took 4.5 hrs.
    i am looking for people to work for me that have the capabilities of producing the above quality in this thread.compensation is between $25-35 per hour depending on the level of your skill.
    This is not an entry level position that requires training.
    You must be able to do shape work.There is a trial period.
    thanks
  9. tobyflh
    tobyflh
    from Peru il
    Is that panel tacked with mig then tig welded? How are you grinding the welds? Love looking at your work.
  10. the metalsurgeon
    the metalsurgeon
    from Denver
    thanks toby, yes mig tacked then grind tacks with this;
    https://www.google.com/shopping/pro....5&ei=Ok8cVMK8McSMyAS_sILIBg&ved=0CKQBEKYrMAM
    you can find cheaper at your local welding supplies,just an example.
    tig weld 1-2" grind top off tig weld with above product,planish weld whilst still hot,so have to move fast.
    then repeat process,tig weld 1-2" etc
  11. Personally at first glance I would not have built either panel the way the photos show. I'm sure there was a reason for why you chose to make a mid panel seam instead of a full one piece repair. If I were 30 again instead of nearly 70 I might have been your guy.
    The Wizzard
  12. K13
    K13
    He was adding a panel to an already existing one.
  13. the metalsurgeon
    the metalsurgeon
    from Denver
    i was filling a panel to match the other side.No panel was 'built' as they were original panels already in existence just like K13 states.
    The seam is right on the cusp of the radius,the beginning of the strongest part of the panel to reduce any warpage.
    As you didn't read or understand the whole thread,i can't help thinking you wouldn't be my guy,but thank you either way.
    Irrational Metalworks likes this.
  14. the metalsurgeon
    the metalsurgeon
    from Denver
  15. the metalsurgeon
    the metalsurgeon
    from Denver
    on to the second set of panels...
    IMG_0858.JPG IMG_0865.JPG IMG_0861.JPG IMG_0870.JPG IMG_0874.JPG IMG_0877.JPG IMG_0880.JPG IMG_0875.JPG IMG_0874.JPG IMG_0877.JPG IMG_0880.JPG
  16. MP&C
    MP&C
    That's just art right there...
  17. Irrational Metalworks
    Alliance Vendor
    from DFW
  18. the metalsurgeon
    the metalsurgeon
    from Denver
  19. the metalsurgeon
    the metalsurgeon
    from Denver
    and all 4 panels completed ready for pick up.
  20. 38Chevy454
    38Chevy454
    Those flat radiused pieces look like COE panels that go under the door. The one with the missing portion you filled in is cut out because it originally went over the battery box, which was on the running board.
    Very nice work!
    the metalsurgeon likes this.
  21. Mr48chev
    I'd think a guy is going to have to have some years of serious metal work behind him to match that on a daily basis.
