COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. onemintcaddy
    onemintcaddy
    Found this day sleeper on an auction sight,,,,,,,,, Cool !
      82.8 KB
  2. shopdawg
    shopdawg
    from alberta
    earlier this summer-[​IMG]
    need to get some removable trailer mirror's, the trailer is hard to see around.
  3. vintagehotrods
    vintagehotrods
    A beautiful COE doing what it was built for! Here is another idea that I have seen done instead of the side rear view mirrors that will have to really hang out there to work. Take a look at the wireless back-up cameras that that you would use on the back of your RV trailer. They come with a small TV monitor (GPS size) you can temporarily mount on your dash. A lot of the large motor homes do this too. A friend of mine did it this way to pull his little Scamp travel trailer behind his '34 Ford Roadster and it works slick. The whole setup usually runs under $100 and you can find them anywhere like on Ebay.
  4. shopdawg
    shopdawg
    from alberta
    Great idea! i'll look into those. thanks
  5. LN7 NUT
    LN7 NUT
    Damn!
    That's a Diamond T!
  6. spankster
    spankster
    Factory tandem axles were not available from Chevrolet until 1956. Anything before that was an upfit from an outside jobber such as Truckstell, Trucktor, Thornton etc. i had a 1954 chevrolet COE chaindrive tandem that was a Tructor Tandem.
  7. spankster
    spankster
    Here's the 1954 Chevrolet COE Trucktor chain drive tandem I had, 1954%20Chevrolet5400-1a.jpg
  8. SwedishEinar
    SwedishEinar
    Thanks for the info!
    The truck looks good!
  9. HOTFR8
    HOTFR8
    Looks like a Mack to me so can we have some confirmation please ?
  10. LN7 NUT
    LN7 NUT
    I have to agree with that too, I'm torn over which it could be.
  11. Novadude55
    Novadude55
    from CA
    I think LN7 NUT was correct the first time,,
    the diamond t hood looks flat, the mack looks like it angles down a bit,
    and i see some of the grill bars in the original diamond t pic kinda matches the other diamond t grill,, and the body beltline matches in the diamonds, its fatter in the mack, kinda hard to tell for sure though given one pic,,
    diamont t:
    mack:
  12. HOTFR8
    HOTFR8
    I have seen a Mack cab here very similar to that and from the USA. Was used as a power utility work truck in the US and is to be restored here. Sorry I do not have a photo but it looks like a Mack to me.
    Having looked at that photo I am going to have to look at the Mack here as I am now confused.
  13. LN7 NUT
    LN7 NUT
    Look at the door tops, the Mack is round, the Diamond T is squared. I'll take one of each though! :D
  14. HOTFR8
    HOTFR8
    I will have to go and see the Mack here being Restored to see the difference. :) Maybe I will get a photo to post here at the same time.
  15. LN7 NUT
    LN7 NUT
    That would be awesome, I love seeing COE's that are not the big 3.
    Spotted this one on the photoshop thread.
  16. HOTFR8
    HOTFR8
    It will be a phone pic but I will get one today all being well.
  17. HOTFR8
    HOTFR8
    Mack.
    Sorry about the quality of the photo.
  18. LN7 NUT
    LN7 NUT
    That is very cool!
    So the one we were questioning is a Diamond T by the looks of things.
  19. evs1
    evs1
    It looks like an old firetruck. Notice how the area under the sleeper has a larger than normal opening? they typically mounted the pump in that area. The red paint and the spotlights are typically firetruck items also.
  20. brett4christ
    brett4christ
    If it's a Diamond T, it's an earlier one. Looks like it's a one-piece windshield.
  21. shopdawg
    shopdawg
    from alberta
  22. That's even the right color Shopdawg!
  23. b-bop
    b-bop
    Couple of COE's sitting on the side of the road in Lake Havasu this week. Both were for sale.
  24. b-bop
    b-bop
    This one from a car show out in the Northwest somewhere.
  25. HOTFR8
    HOTFR8
    Perhaps the cabs used only front sheet metal and the back section was built by a Coach builder ? I see similar lights stc. on both trucks. The firm restoring the power company Mack truck are aware some of the earlier cabs woud have been one off Coach company builds.
  26. MCI5C
    MCI5C
    from peabody ma
    Whats involved in making my 51 chevy coe cab tilt forward for easy access?
    Thanks
  27. evs1
    evs1
    Unless you own or can afford a serious fab shop, you better let that idea go. Steering shaft will have to be custom, brake controls will have to be figured out, wiring is a whole other headache. Then you have to figure out the geometry involved getting the cab tilt to work properly. You're probably looking at doubling the cost of the restoration.
  28. JF
    JF
    from Utah
    if you had access to a Ford C cab it might be worth spending 20 minutes crawling around and under it to see how they tilt and everything is oriented. wonder how easily (or difficult it would be) if you could use all the components from a donor C cab???
    lots of work up front but think of how easy it would be to work on the engine later!
  29. JF
    JF
    from Utah
    oops double post. dumb smart phone!!!
  30. DenK
    DenK
    Mc15c.. Did a little tape measure work on a short Isusu and a
    White 3000. Isuzu had a 350 Chevy and 700R4 stock.Looked promising
    except for wheel fit in the fenders. I Need to push snow so I p***ed.
    I think with the new quick mount plow frames that would work too.
    There was room for a 8 or 9 foot dump body too. Might be worth
    a look. Good luck with your Chevy.
