COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. HOTFR8, I stole your wing idea, before I saw your avatar, great minds think alike. I want to make mine convertible so when towing my travel trailer it will push the air over the top and when bob-tailing having it like yours is just bad ***!
  2. Lots of reading, but it is all right here in this thread. Less than 200 pages! LOL
  3. HOTFR8
    HOTFR8
    I think mine must make a big difference when towing a trailer with air flow etc. and fuel economy. Something you could also think about is a mount for a third brake light as I have small LED's hidden under my wing.
  4. v8steel
    v8steel
    Hey Seth;
    Been doing fine. Very busy at work. Always chasing that next dream (build or bright idea) that gets to wait in line for all the other dreams that come first. Hope all is well. See ya!
  5. I plan to run an old timey pair of stop lights with the word STOP in the lens on the back of my sleeper. I suppose someone will run into me while texting their buddy about the neat light they saw on the back of an old truck.
  6. HOTFR8
    HOTFR8
    That would look good. I still run the standard Peterbilt stop tail lights in the back of mine as well as the lights under the wing and on the rear bar. The more lights for them to see the less chance they will run into you (hopefully).
    My sleeper to fit the 48 Ford cab had the full chop channel and section to make it suit.
  7. mammyjammer
    mammyjammer
    from Area 51
    All Ford sounds like a a great plan and stacks like those do need black smoke comin' out of 'em!!!!
  8. HOTFR8
    HOTFR8
    You want zero black smoke as that is wasted unburnt fuel and to be able to leave dead at the lights wondering what the hell was that. It is much more fun :);):)
  9. kscarguy
    kscarguy
    Nice truck
    Things to be concerened about...
    1. Where the front tires are in the wheelwell. They should not be dead center, but slightly forwards by 1/2". It will look better...never behind center.
    Oops, Gotta go to breakfast, hopefully others will add in...
  10. daddio211
    daddio211
    Yep. It amazes me how people think thick clouds of black smoke are cool. In fact, it just means your diesel runs like ****! Tuned right they run clean and make a lot more power.
    Sent using the NEW Droid HAMB app from atop my toilet.
  11. Running so much fuel you're close to hydro-lock raises your compression ratio, don't you know. LOL
  12. kscarguy
    kscarguy
    to continue...
    ....Swapping the frame may cause ***le issues. Check with your state. to see if you need an ***emble vehicle ***le...that may also cost higher yearly taxes.
    ...ride height might change due to the weight of the COE cab. Using a light cab and moving the engine to the back results in not enough weight to move the front suspension from where it sat on the donor vehicle. On my 41, I use 1/2 ton springs with a coil cut off.
    ....steering, always seems to be a problem. Your cab is wider and should not be as much of an issue. as the 38-47 Ford COE.
    ...brakes, hang the pedal when possible, you will find that it is far more comfortable than a under floor master.
    ...build thread, start a thread and share your project with us. We like to see what you other crazy COE guys do!
    ...and lastly, pizza, when is the doughboy going to give us all free pizza? HA!
  13. HOTFR8
    HOTFR8
    Here blowing to much smoke would mean getting put off the road and being told to fix it. Better to make lots of (Diesel) noise and no smoke as that makes them wonder what left them at the lights.
  14. gjcat56
    gjcat56
    Dondogarage, I would not use the econoline ch***ie. It is wider than a regular F series frame. You can use a super duty frame as they have straight axles and come in 16 and 17.5 wheel sizes. 16" wheels look a little small in the 53-56 COEs. They are a frt steer and wouldn`t take a lot to hook up. The engine setback may be problematic, there isn`t alot of room in the engine compartment. In fact the original engine sits under the floor halfway. Putting a six diesel uses alot of footroom realestate. On my 56 I`m staying with the original ch***ie and up grading the brakes and steering. Looking for a 7.3 turbo diesel (non powerstroke) to install with a clark 5spd and the 2spd rear.
  15. kscarguy
    kscarguy
    Just curious, Is the Econoline track width wider than a F-truck, or is it just the frame rails?
  16. gjcat56
    gjcat56
    I beleve it is.
  17. MCI5C
    MCI5C
    from peabody ma
    Hi,
    I have a 51 Chevy COE. I hope to replace the straight 6 with a v8. Will a 350 block fit in the same spot as wher the 6 was. I do not want to put it behind the cab. Any one do this conversion?
    Thanks
    Chris
  18. I saw this at LARS this weekend,
      377.8 KB
      392.8 KB
  19. phat rat
    phat rat
    It'll fit. I just ran across one yesterday that was done that way.
  20. MannyK
    MannyK
    from NYC
    Love this thread!!!!!!!
  21. rottenleonard
    rottenleonard
    So I just bough this 42' chevy and it's way out of town and I need to go pick it up, I measured the wheel base and that will fit on my trailer but didn't think to measure the width of the front tires to see if it would go between the fenders of my trailer. Anyone know for a fact how wide the outside of the front tires are? It has 20" budd wheels
  22. I don't know widths, but if too wide think about pulling the outside duals and backing it on.
  23. LN7 NUT
    LN7 NUT
    I hired a tow truck to bring my 56 Mercury M700 home, I didn't want to risk anything, it was expensive (even with my employee discount) but the piece of mind and lack of stress was worth it.
  24. I don't know what "way out of town" means to you, however with my AAA Plus, I can get a tow for up to 100 miles.
    Tappster with my Galaxy S iii.
  25. LN7 NUT
    LN7 NUT
    My AAA wont cover stuff like this, only registered vehicles I am driving/riding in.
  26. b-bop
    b-bop
    Not sure if they are the same width, but I pulled the outside of the duals off my 38 and hauled it from Puyallup to Calgary up and over the Continental divide, 800 miles, no problems
  27. rottenleonard
    rottenleonard
    It almost looks like the front tires are between the fenders on your trailer. good sign.
  28. kscarguy
    kscarguy
    Good idea to back it on. When I bought mine, the trailer width was no problem...then I got it home and discovered it was too tall for my garage door...! Now that was a problem. :)
  29. Locomotive Breath
    Locomotive Breath
    from Texas
    Backing it on is ok as long as you have enough tongue weight. Things can get ugly quick if they're tail heavy. Will also burn a lot more fuel towing it loaded backwards.
  30. kscarguy
    kscarguy
    Yeah, since they are soooo areodynamic pointed forwards...HA!
