COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. mgtstumpy
    mgtstumpy
    Stumbled onto this some time, lots of work getting to this stage
    Hotrodmyk and ME.GASSER like this.
  2. Marty Strode
    Marty Strode
    I haven't posted anything on my '53 Ford for some time now. Recently I made some progress and it should be on the road next year. Here are some shots of the "dog house" in the raw and finished state. The 460 is finally getting all of the accessories installed, along with a US Gear overdrive behind the C-6 trans. Side tool boxes are being installed for the last time. IMG_4980.JPG IMG_4984.JPG IMG_5010.JPG IMG_5013.JPG IMG_5018.JPG IMG_5017.JPG
    Baron likes this.
  3. Marty, I don't know what you have in mind for cooling, but 460s like to produce lots of heat. I had one in a Stude pick-up and it nearly drove me crazy trying to keep it from boiling.
  4. Geets
    Geets
    from NJ
    That's some nice clean work there!!
  5. Marty Strode
    Marty Strode
    I don't foresee any cooling pro 53 COE.jpg blems, it has a large frontal area for air movement, and no restriction for the hot air to escape. I bought a new radiator for a 460 pickup, and plan on using a large OEM clutch fan with a shroud. The COE grille is 10" longer between the headlights than a pickup. We will find out next Summer. Thanks Geets
    enloe likes this.
  6. You are probably OK, the Stude had a quite small grille opening with a very full engine compartment.
  7. Baron
    Baron
    Hi Marty. Looks like your going to have a very nice COE when finished. They are a blast to drive. Of all my vehicles, my wife like the 47 cab-over best. Look forward to seeing the finished product.
  8. dondogarage
    dondogarage
    from richmond
  9. dondogarage
    dondogarage
    from richmond
    Hi MATTY like your truck getting ready to start my 55 coe. look all over hamb couldnt find any other post or pictures of your build. would like more information like ch***is you used.thanks If you would call me would like to talk thanks. Virgil THANKS
  10. Marty Strode
    Marty Strode
    I used a 1979 E350 bread truck ch***is on this one. On a '48 Ford COE I used a mid-70's Dodge Motorhome ch***is. If you want it to set low,(d**** the body over the frame) I would probably use the Dodge ch***is. The box on this one dictated the cab height, and I got two bread trucks for free. They were used in the Tommy Lee Jones movie "The Hunted", and one had been rolled.
  11. 38Chevy454
    38Chevy454
    Nice work Marty, I see you kept the cab a bit higher relative to frame so the engine does not intrude so much into the cab.
    My 49 COE has a generic alum radiator across the core support and runs right at thermostat temp all the time. Whatever the width between the sheetmetal, my radiator is fins for all of that opening width. Even have A/C and still runs cool.
  12. dondogarage
    dondogarage
    from richmond
  13. Marty Strode
    Marty Strode
    If you already have an E350 ch***is, I would set the '55 body on it and take a look. I am unfamiliar with the physical height of the diesel engine, and that would be the limiting factor for me. If you look at these pics you will see that I could have shortened the front body mount, and set the body 4" lower. In my case, I wanted to retain the bench seat and keep the "dog house" height to a minimum. Also, if you look at the picture of the t IMG_5117.JPG IMG_5119.JPG IMG_5120.JPG ruck in it's original blue paint, you will see the running boards are level with the bottom of the cargo box. When finished, I am going to build something similar to a tilting trailer frame (complete with fold out ramps and a winch) that I can install in the box. The frame will be removable in minutes with a fork lift. When installed, I can haul a race car or hotrod inside, or remove it for parts hauling and swap meet duty. It will make a handy hauler for up here in the rain country.
  14. [​IMG]
    DARE TO BE DIFFERENT !!!!!
    Bill in Oz
    Tuff Tin and ME.GASSER like this.
  15. I'd like to meet the person that thought that up, bet he has a built in giggle!
    Looks to be left hand drive, any idea where it lives, Bill?
  16. HOTFR8
    HOTFR8
    Bill, We do need to see more photos of that.
  17. b-bop
    b-bop
    Saw him at Run to the Sun last year. Not everyone's cup o tea, but cool none the less. Dare to be different.
  18. gonmad
    gonmad
    Looks like something porky pig would be driving! LoL! But I dig it all but the wheels.
  19. v8steel
    v8steel
    ... and call it POR-COE.
  20. daddio211
    daddio211
    I'll say it, it's hideous! I respect the work but there's no balance to the design.
  21. daddio, I respect your opinion, but can you explain balance? I like it because it is different, I'm bored by most every car at a show looking like one I've already seen somewhere before. so the "unusual" catch my attention. (Oh look, a squirrel, type of thing)
    daddio211 likes this.
  22. HOTFR8
    HOTFR8
    I can see the relation to the Mack Dog and the squat nose. It has that Bulldog look you would have to grow to love just like you would if you owned a Bulldog. He has done well to keep it all in proportion.
  23. b-bop
    b-bop
    Someone photoshop some good lookin steel wheels on it and see if that makes a difference
  24. uncle johnny
    uncle johnny
    My boy has started on his first ride
  25.
  26. smack1984
    smack1984
    Found a couple online today.
  27. About the best I could get while in moving traffic today; on 290 heading towards Austin around 1 hour ago.
  28. That guy is looking at the camera/phone and thinking, Oh f--k, I'm so busted!
    Back it the 60s my dad drove one of these (Chevy version) with a 409 in it. Rod bearings were good for about 10,000 miles. GM tried everything to get it to hold together, new block, align bore, new crank a couple times, nothing helped.
  29. The brown one that willysbill posted--- Anybody know what it's powered by? I see it's rear engined and those look kinda porsche-ish wheels.
  30. King ford
    King ford
    from 08302
    That red black and green gmc SO reminds me of trash trucks that used to come in to the spring repair shop I worked at in the seventies....they all had those huge v sixes in em.......
