COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. vintage56
    vintage56
    Exactly
    I’ve seen a few of these (or this one multiple times) through the years, all listed on uPaY. One had the flat bed removed and the reframed rear ch***is could be seen. I probably have pics on a thumb drive somewhere. If I find them, I’ll post them up here.
  2. vintage56
    vintage56
    Ps. I wish they all could be California trucks.
    Much less cancerous
  3. HJmaniac
    HJmaniac
    It probably has what is called a beverage truck ch***is. Lower to the ground for easier unloading for the beverage driver.
    Here is the White 3000 version.
    Gary Man likes this.
  4. vintagehotrods
    vintagehotrods
    Now that's a lowrider! It would be a great car hauler. I'd sure like to see how they did it. Any suspension? Solid mounted axle? Drive shaft set-up? A picture of the ch***is would really be worth a thousand words! Great find, thanks for posting.
  5. wetskier2000
    wetskier2000
    from NH
    I think this frame is even lower than that White 3000.
  6. vintagehotrods
    vintagehotrods
    Much lower, I don't see how the pumpkin of of the differential fits under the bed because the hub is centered on the bed/frame rail. That's what makes me think that rear axle is solidly mounted with no suspension and the bed floor is right on the top of the pumpkin. Even at that it still doesn't even look like there is room for it. If somebody from the area looks at it I would love to know what they see under there.
  7. wetskier2000
    wetskier2000
    from NH
    Here's a shot without the headache rack... Looks like the truck's frame is above the bed..
  8. vintagehotrods
    vintagehotrods
    It almost looks like they welded the frame for the bed underneath the frame the cab is sitting on in front. Is that a small bump or cover over the driveshaft up in the front of the bed?
    Looks like we'll never know now because it must have sold and because the seller deleted the ad. I hope a HAMBER bought it and tells us the rest of story.
  9. wetskier2000
    wetskier2000
    from NH
  10. b-bop
    b-bop
    Latest COE to pop up in the neighborhood 51C0653B-9A20-4DBE-B5CC-1B1D7DDE49A9.jpeg
    OahuEli, JOYFLEA, shopdawg and 3 others like this.
  11. wetskier2000
    wetskier2000
    from NH
    OahuEli, JOYFLEA and HJmaniac like this.
  12. shopdawg
    shopdawg
    from alberta
  13. Have to sell a lot of pizza to pay for that build! Never have figured out the economics of it.
    b-bop likes this.
  14. wetskier2000
    wetskier2000
    from NH
  15. vintagehotrods
    vintagehotrods
    It sure looks like it Steve, but now with a car hauler flatbed. Same steering column, dash and step in the front fender. A good deal for a built truck. I wonder how well the little Izusu diesel four moves it down the road?
    [​IMG] [​IMG]
  16. By the displacement, this is the very common 4bd1t engine,
    Cylinders: 4
    Injection: direct
    Injection pump: Bosch/Zexel type A inline pump on RHS (drivers perspective)
    Bore: 4.0157in
    Stroke 4.6457in
    Valves: 8
    Inlet manifold separate casting RHS (drivers perspective).
    Exhaust LHS (drivers perspective).
    Weight: Approx 770lbs turbo. 744lbs NA (source Isuzu spec sheet from 1988)
    Dimensions NA: 31.3in long x 27.8in wide x 29.7in tall.
    Bellhousings: SAE #3 automotive (rare), SAE #3 industrial (rare), Landrover LT85/95 (rare), Isuzu truck pattern (most common).
    Starting aids: Glowplugs and excess fuel.
    Electrical: 12v in US market, 24v in rest of the world.
    Turbochargers: IHI RHB6 (early), Garrett T25 wastegated (early), Garrett T25 freefloat with T3 flange or Garrett T25 wastegated with T3 flange.
    Alternator: 12v or 24v depending on market, vacuum pump on rear. Located high on LHS (drivers perspective).
    AC Compressor: if fitted below alternator on LHS (drivers perspective).
    Power output NA: Varies but up to 104.6hp @ 3200rpm.
    Torque output NA: Varies but up to 194ftlbs @ 1900rpm.
    Power output Turbo: varies but up to 140.8hp @ approx 3000rpm.
    Torque output Turbo: Varies but up to 243.4ftlbs @ approx 1800rpm.
    (On the highway, one is always running over Isuzu box trucks)
  17. vintagehotrods
    vintagehotrods
    In 2007 Izusu started offering the GMC 6.0L LS as the standard motor in them, that would be a great ch***is and engine to use.
  18. Shortly after I bought my Autocar, I picked up a 1990 NPR to use as ch***is and power. After getting it home and doing a bunch of measuring, I realized the track width was way to narrow for the Autocar cab and there was severe rust jacking between frame rails and cross members. My ch***is also had 5.13 gears so I would have been very limited on top end and I felt the engine wouldn't have had the snort for higher gearing. I wisely got out the cutting torch, junked the ch***is and took the financial hit. I still have the engine and trans. (I think it would be a good fit in an older Dodge Dakota)
    The Isuzu ch***is appears to be a much better fit under this Ford.
  19. wetskier2000
    wetskier2000
    from NH
  20. Metal Mover
    Metal Mover
    from Jamul CA
    At the Good-Guys, Scottsdale last weekend saw this. Going on the block at Barret-Jackson in January. Over the front tandem axle is an opening with a fifth wheel hitch, it should be in their catalogue.
    b-bop likes this.
  21. I see it has an early 60s Chrysler dash, to me, those are one of the coolest ever built!
    OahuEli and b-bop like this.
  22. wetskier2000
    wetskier2000
    from NH
    2 pretty rough COEs at the local boneyard. $4500 for both.. The better 38/39 has a decent 41 grill kept inside...
  23. wetskier2000
    wetskier2000
    from NH
    Baron likes this.
  24. wetskier2000
    wetskier2000
    from NH
  25. Wetskier, all it takes is one rich idiot!
    I know it has been almost 20 years since I bought my Autocar, but at the time $958 was top bid for a truck that is about 50 times more rare than that series Ford and about the same condition
    vintage56 and OahuEli like this.
  26. wetskier2000
    wetskier2000
    from NH
    Only in New England...
    b-bop likes this.
  27. spankster
    spankster
  28. spankster
    spankster
    My 1952 GMC 470 series COE, 3 1/2 ton, Heavy Duty Holmes Wrecker.. 20211228_154244_  2.jpg
    OahuEli and wetskier2000 like this.
  29. shopdawg
    shopdawg
    from alberta
    Sold at Barrett Jackson, built by Dale Gerry in Kelowna BC. 465thousand 44F90778-14EA-47B3-AF58-159D6CEA3E3D.png
    b-bop and vintage56 like this.
