COE COE Picture thread (imported from main board)
Discussion in 'Off Topic Hot Rods & Customs' started by Duration, Oct 30, 2007.
  1. Starbuck_88
    Starbuck_88
  2. daddio211
    daddio211
    Everytime I see this thread pop up it makes me laugh. "Can we start a COE picture thread?"
    Yep, we started it. And it's almost 100 pages long!
  3. cckid
    cckid
    The coe's are really neat, I have 2 coe Chev. ***les a 1940 and a 1953, these are listed as Chev. tractors. Pm if interested. John
  4. hotroddon
    hotroddon
  5. el shad
    el shad
    FOR REAL!!!???? That is BAD ***!!!!
  6. mart3406
    mart3406
    from Canada
    If you don't use the HAMB "quote" option
    to quote at least a portion of the original
    message at the top of your post, nobody
    here reading your comments knows what
    post you're referring to, or what is
    supposedly "FOR REAL!!!???" and so
    "BAD ***!!!!"....or what the hell else
    you are talking about.
    Mart3406
  7. mart3406
    mart3406
    from Canada
    Any more details on this rig?? It's
    truly 'outrageously amazing' and
    we 'inquiring minds' here absolutely
    *NEED* to know more!!! :)
    Mart3406
  8. el shad
    el shad
    Is this better dumb ***? Pull your thong out of your ***, and put on your big boy *******. If little things like this get under your skin so easy life must be very difficult for you.
    I was referring to the yellow rig with the white trailer in the prior post to mine, and no I'm not going to edit it.
  9. nyvp
    nyvp
    Question. I'm looking for a semi late model vehicle for a 48 ford coe i'm looking at buying. I know the older truck and motorhome frames work , but i'm looking for something a bit smaller and better handling.I was looking to build a COE family vehicle with 4 door and three rows of seats to go on the long trips with. Any suggestions for a late model frame ? ext pickup , sprinter ect... Thanks
  10. daddio211
    daddio211
    I'm not certain, but this looks just like some photos/sketches that Larry Woods (Hot Wheels fame) showed me of a project he was building about 10 years ago. Wouldn't surprise me at all if this is his... too *****in!
  11. HOTFR8
    HOTFR8
    This may give you an idea. http://www.ozcoetrucks.net16.net/Kuchel541.html I am sure it has been posted here before and perhaps bigger than you mentioned but as I said it may give you an idea.
    and finished.
    Edited note: Not mine and the back is like a home away from home.
  12. onemintcaddy
    onemintcaddy
    Welcome to the HAMB *** Hole Club,,,,,,,,,,,,:D
  13. el shad
    el shad
    I'm trying my hardest to read what you just wrote, but my eyes keep wondering slightly left to your avatar before I can finish the sentence.
  14. crazyhillbilly
    crazyhillbilly
    no its a diamond t step van its sweet a little rusty but will be sweet rod material i need to find a hood and grill
  15. crazyhillbilly
    crazyhillbilly
    found out its a diamond t step van model 306 belive to be a 48 but having a hard time finding a decoder for diamond t ch***is/ vin numbers, its missing the grill and hood the chevy one inside of it is a 38 pickup one
  16. crazyhillbilly
    crazyhillbilly
  17. 47 GMC BURB
    47 GMC BURB
    Sweet score...
    Do you have any info on FWD/COE conversions I need one for my Wife..
    Strange there is allways $$ for her projects...humm:eek:
  18. Truckeez
    Truckeez
  19. Baron
    Baron
    Finished the rear roll pan. Ready for final sanding and primer.
    Welded the stake pockets together and bolted to bed sides. Need to grind the welds, little bondo work and they will be ready for primer.
  20. Sledge
    Sledge
    from Nor Cal
    Man, thats the one I need!
  21. COErod
    COErod
    Hey Crazyhillbilly.
    Go here, put in your VIn #. It'll tell you everything you need to know.
    http://www.vinwiz.com/
  22. pex
    pex
    from alberta
    A updated photo of my 1/2 ton. [​IMG]
  23. OahuEli
    OahuEli
    from Hawaii
    Looking good! Are you still going to do the bed for your speedster?
  24. pex
    pex
    from alberta
    yes on the deck but i traded the speedster off on a 29 model A roadster. i've got the rear running boards fabbed up and have decided that the rack for the roadster and the skirting will be independent of each other so i can have the rear fenders with a full skirt flip up to access the engine or change a tire even if the car is on the back. i'll get the outer skirting part done first. i took ten days off work to work on the truck and have gotten a lot done but a little burnt out.
  25. OahuEli
    OahuEli
    from Hawaii
    That sounds like a pretty cool plan! What engine are you using? I think I'll try to Photoshop your idea if I can remember what the hell I did.:D
  26. pex
    pex
    from alberta
    This rendering is my goal look. [​IMG]
  27. pex
    pex
    from alberta
    this rendering is the goal look| [​IMG]
  28. Ed Wrath
    Ed Wrath
    Calvin Evan's.........We havn't got many over here, but they don't come much cooler!
  29. roofer
    roofer
    from uk
    This Coe makes you stop in your tracks, this is the muts nuts, there is nothing you could do to improve this truck,,
    Roofer
  30. OahuEli
    OahuEli
    from Hawaii
    Here's your tilt bed version. I had to go back and figure out what I did on the original one before I could do this. lol BTW the only engine I could find with a close angle was a Ford Cammer.
    [​IMG][/IMG]
