Hot Rods coil over shocks ??
Discussion in 'The Hokey Ass Message Board' started by putz, Aug 29, 2025.
Tags:
  1. putz
    putz
    from wisc.
    because of clearance can i use without using coil , what to expect ?
  2. RodStRace
    RodStRace
    A coil over is 2 parts in one. A shock and a spring. If you just want to use the shock portion, it should work, BUT you still need a spring to support that corner and regular shocks are usually cheaper and smaller.
  3. Budget36
    Budget36
  4. twenty8
    twenty8
    swade41, Bandit Billy and Budget36 like this.
  5. jaracer
    jaracer
    Their is a mistaken belief that a shock alone supports vehicle weight, it doesn't. A shock's only job is to dampen the up and down motion when hitting a bump.
    saltflats, Just Gary and X-cpe like this.
  6. twenty8
    twenty8
    Are you using another type of spring to suspend the vehicle's m***...???
  7. alchemy
    alchemy
    Opposing magnets is an option.
  8. Bandit Billy
    Bandit Billy
    Clever. Apt, correct and educational but clever, nonetheless.
  9. saltflats
    saltflats
    from Missouri
    There is a difference between a coil over shock and a spring ***isted shock.
  10. gimpyshotrods
    gimpyshotrods
    The threads will act as cooling fins.
    saltflats likes this.
  11. twenty8
    twenty8
    Adjustable electromagnetic shock absorbers do exist. developed in the racing sector to allow mid-race tuning and tweaking.
