Coil over spring rate ?
Discussion in 'The Hokey Ass Message Board' started by angelotti86, Mar 11, 2014.
  1. angelotti86
    angelotti86
    I flipped my rear end on my 56 truck and I am not notching it so I am going to put some coil over shocks to give it a but more help so doesnt bottom out easy .I am not sure what spring weight I should get being that there just helper springs not the sole supports .
    There is 250lb 350lb 450lb and 650 lb .
  2. King ford
    King ford
    from 08302
    If you keep the original leaf springs and add coil overs your gonna have one rough ridin sumbitch ! Even if you go with the 250 s the shock mounts probably aren't strong enough
  3. angelotti86
    angelotti86
    so another words go with the lightest rate avail
  4. hard to know without knowing the weight of the vehicle , shock angle , etc
    just so i understand..you flipped the rear end to the top side of the rear leaf springs , and now the rear end is too close to the underside of the frame rails. and now you want to add more spring so it doesn't go bang? why not just notch the frame?
  5. angelotti86
    angelotti86
    Exactly and I want the bed to look stock so c notching will cut into bed .I know there was another guy who did this but I can find it now .
  6. Why can't you just install stiffer leaf springs? or add a few leaves to your existing leaf springs??
  7. i flipped a diff on a 57 chevy only put a 5" notch used a piece of round tubing as filler used the stock springs and bed
  8. angelotti86
    angelotti86
    I dont see what the difference is since people put air shocks all the time .Isn't that the same idea to give the rear extra stiffness or lift ?
  9. Stonebird
    Stonebird
    How about hydraulic bump stops like the off road guys use?
  10. Hnstray
    Hnstray
    from Quincy, IL
    This is one of those deals where want you want can't be done without making concessions. If you want the truck to be lower AND you want a decent ride quality, you need to notch the frame or install an IRS. On the other hand, if you refuse to consider notching the frame, or alternate suspension style, you may need to accept either a harsh ride and/or 'bottoming out' for lack of clearance. Read my signature line.....it's not MY rule.....but it is THE rule.
  11. gimpyshotrods
    gimpyshotrods
    That's a bad idea, too.
  12. dave lewis
    dave lewis
    from Nampa ID
    Factory shock mounts were not designed to carry weight.
