1952-59 Ford Coil Spring Replacement
Discussion in 'Off Topic Hot Rods & Customs' started by Black Wagoon, Aug 28, 2019.
  1. Black Wagoon
    Black Wagoon
    Fellers,
    When replacing the stock Front Springs w/ Aerostar units, is it necessary to remove the balljoints to make it happen or will a Spring Compressor compress the springs enough for removal with the Ball Joints still in place?
    I presume the Tie Rods will need to be removed.
    Thnx
  2. fordsbyjay
    fordsbyjay
    from Lafayette
    You have to remove one ball joint (usually the bottom one).
    Loosen the nut on the lower ball joint 1/4" or so and hit the side of the balljoint/control arm area and the spring pressure will pop the lower ball joint loose. then just put a jack under the lower control arm and jack it up to take the load off the lower ball joint, remove the lower ball jt nut all the way and slowly lower the jack till you can take the spring out.
  3. 54vicky
    54vicky
    jay described the method to a T if you have torch it makes it a snap if you cut one of the coils.main thing is only loosen nut do not remove without jack under.
  4. Did you use the CC850 springs?
  5. Paul2748
    Paul2748
    Jay is right, but before you do anything wrap a piece of chain around a coil of the spring and the frame as a safety precaution.
  6. Black Wagoon
    Black Wagoon
    Thanks!!
    Since I'm using the spring pressure to unseat the Ball Joint, and I'm not boogering it up with a pickle-fork, shouldn't I be able to reuse the old balljoint again?
    Yes, Rev, the plan is to replace the stock springs w/ the Aerostar units.
  7. 56longroof
    56longroof
    Yes,the balljoint will be fine.
    Black Wagoon likes this.
  8. 54vicky
    54vicky
    the balljoint will probably survive but the boot may not they usually do not as jeff has suggest many times maybe order from ES
  9. okiedokie
    okiedokie
    from Ok
    I have a ball joint separation tool that I made from a 1/2 bolt with the head cut off and a nut on each end that allows separation with no damage to joint or boot. I will post as picture later. You can purchase ready made ones also.
  10. BruceMc
    BruceMc
    from Alaska
  11. jimmy six
    jimmy six
    You do not "remove" the ball joint just take it out of the wedge in the spindle. On all the ones I've done we loosened the upper nut a few threads and used a splitting device which lengthens when holding one part with a wrench and turning the threaded part. (put anti-seize on the threads before starting) Bought it from the Circle Track section of Speedy Bill years ago. Then put a floor jack under the lower a-arm to complete the job. We always needed the jack stands on the frame behind the wheel to get it high enough to make it easier. Done it this way more time than I want to count..good luck
  12. jimmy six
    jimmy six
    Stock 56 spring and CC850 Aerostar with pad. Lowered front 2"s
    56longroof and guthriesmith like this.
