Technical Coil spring spacers
Discussion in 'The Hokey Ass Message Board' started by 68caddydaddy, Aug 24, 2026.
  1. 68caddydaddy
    68caddydaddy
    Hi, I installed a set of new tires 215/75 R15 , replaces the 7.10 white walls. The car is lowered 2" and has disc brakes. The new tires are rubbing the inside of the fender. Can I add a 1/2" spacer on top of the coil spring to have more space and avoid rubbing. Are there companies who sell the spacer or do I have to make it myself ? (1954 chevy 210 Handyman)
  2. lostone
    lostone
    from kansas
    In most cases realize that the spring spacer, if installed under or on top of the spring will usually double the raise. So a 1/2" spacer will get you close to an inch. Just FYI....
    68caddydaddy likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. rusty1
    rusty1
    those rubber ones work great under the coil.
