Coil ?
Discussion in 'The Hokey Ass Message Board' started by Jdee, Dec 1, 2003.
  1. Jdee
    Jdee
    My Coils look like this..Pic
    If I cut them the clamps Won"t Catch?
    How do you all get around this.
    I'm getting new springs if I have to [​IMG]
    But these like this won't work.
    39 Buick, Just to tall.
    Jdee [​IMG]
  2. Do you have a spring shop near you? Give them a call. You should be able to get new shorter ones made. Shouldn't be all that expensive
  3. Jdee
    Jdee
    Yeah I got a price not bad, I think I might cut these and stick them in just to see about the drop I want.
    They fit up into the frame a few inches so I should be safe I guess. The bottom really needs clamped though...
    I got my top back on and just trying to get an idea of how much to lower things.
    Jdee
  4. Makes me a little nervous seeing that all twisted with the top off! [​IMG]
  5. Jdee
    Jdee
    The top is back on and everything is fine.
    It was braced and the car has no rust at all
    so that helps a lot.
    Buick sure put a lot of lead in their tops, up
    to a 1/4" thick on both sides on the back area of the roof.
    Both sides exactly the same [​IMG]
    Jdee
  6. Cars lookin good! That amount of lead is not uncommon. Last 35 ford coupe I did was bad. Close to 1/2"on both sides at the factory joint. It looked to be original. After I melted it out, I had to heat, bend and shrink to get it close enough to fill the top.
    Do you have a profile shot of your car from further back? I think it will have "the look"!
  7. Jdee
    Jdee
    This is an old shot, Not to clear.
    But shows the shape of the car before the chop.
    and there are a few shots on my Homepage.
    Jdee [​IMG]
  8. Rocket88
    Rocket88
    Chevelle's, Chevette's, Monza's all have a similar coil spring arrangement. Springs out of one those should work. You'll just have to experiment a bit to get the ride height you want.
    The car is lookin' good so far!
