Technical coiled fuel line vs straight
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Jun 22, 2017.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    Can I cut either and use compression fittings? I know the coil is 20 something long. Working on a 58 gmc pickup 6cylinder with Holley 4barrel carb.
    Thanks
  2. thisguy65
    thisguy65
  3. dtwbcs
    dtwbcs
    from Brenham,TX
  4. mgtstumpy
    mgtstumpy
    I ran hard line from tank to front frame rail where I used a compression fitting that connected to flexible line and up to engine. Just unroll the coil on a solid surface and it should be pretty straight. Keep coil vertical and at right angles to ground and unwind slowly. Cut the tubing square where you want the end to be.
    This is the tool referred to but not cheap. It handles tube from 3/16" to 1/2". End rollers are fixed and centre is adjustable so tubing can be straightened. Do a p*** and then clock tool 90 degrees for another p*** and it should be right. Then you have to bend it. Use the OEM if available as a pattern.
    lothiandon1940 likes this.
  5. 48stude
    48stude
    I drilled a hole ( slightly bigger than the tubing )though a piece of wood 4 x 4 , chucked it in a vise and pulled the tubing through the hole back and forth a few times. Lubing it with some oil helps. Crude ,but works . I have since bought a straightener as mentioned above. Kind of expensive but works good. Bill
  6. squirrel
    Might want to use double flare fittings instead of compression fittings....????
  7. Mike51Merc
    Mike51Merc
    Double flare for low pressure fuel? Then he'll need double flare female fittings to match.
  8. RmK57
    RmK57
    Inverted flare (double flare) brake fittings would be my first choice to.
    Blues4U likes this.
  9. Blues4U
    Blues4U
    from So Cal
    There is no "double flare" fittings, it's an inverted flare fitting, and the fitting doesn't care if it's a single or double flare. Doing a double flare helps prevent cracking and ensure reliability.
    dtwbcs likes this.
  10. squirrel
    yup....and I mentioned double because I was too lazy to type out your excellent explanation.
    1927graham likes this.
  11. Mike51Merc
    Mike51Merc
    The double (inverted) flare is 45 degrees and single AN flares are 37 degrees, so the fittings are different. Just sayin'.
    Blues4U likes this.
  12. Blues4U
    Blues4U
    from So Cal
    Thanks for straightening me out on that.
    dtwbcs likes this.
  13. gimpyshotrods
    gimpyshotrods
    I am just going to use JIC fittings.
  14. manyolcars
    manyolcars
    JIC fittings sound expensive and way overkill. JIC fittings are widely used in fuel delivery and fluid power applications, especially where high pressure (up to 10,000 psi) is involved.
  15. gimpyshotrods
    gimpyshotrods
    I'll just braze everything together, then.
  16. dtwbcs
    dtwbcs
    from Brenham,TX
  17. theHIGHLANDER
    theHIGHLANDER
    Hey dtw, this was just getting good...;)
    gimpyshotrods likes this.
  18. dtwbcs
    dtwbcs
    from Brenham,TX
    Yeah I moved on to another post so I can get the truck finished soon[emoji851]
    Bugguts likes this.
  19. Mr48chev
    Compression fittings will work ok on fuel lines as long as you support the line the fitting is on well. In the past I always bought lengths of the right size tubing at the parts house with the inverted flares installed and used the proper fitting to connect the. Just lately I bought a roll of 3/8 tubing that I will join the "how the hell do I get this real straight" brigade with. Since I have an Eastwood flair tool I will probably run flair fittings all around. Thinking about it my 71 GMC has had a compresson fitting in the line for years after I took the stock seat tank out and extended the fuel line. That was one of those quick and nasty gotta get it done now things though.
    dtwbcs likes this.
  20. dtwbcs
    dtwbcs
    from Brenham,TX
  21. dtwbcs
    dtwbcs
    from Brenham,TX
    saltflats likes this.
  22. Fortunateson
    Fortunateson
    I wouldn't paint it, it gives definition to the engine bay.
  23. dtwbcs
    dtwbcs
    from Brenham,TX
    I was thinking flat black to match the accessories on the engine
  24. sunbeam
    sunbeam
    Diesel injection lines use compression fittings a 3000 to 4000 psi I think you will be OK
  25. dtwbcs
    dtwbcs
    from Brenham,TX
    Thanks beam I finished that project
